http://www.youtube.com/watch?v=QvcJKPHmFQQ
This is my second project using the 08m2 to output a clock signal to a cmos 4026 counter.
Took a bit of brain bashing to work this one out. The sneaky hall sensor just keeps sending out a positive voltage so the picaxe goes mentl and the counter is all over the place.
So I used a cmos 4011 to cancel that signal to 0 volts so the the 08m2 is unaware anything is there. Then when the magnet passes it reverses the negative to a positive and the 08m2 wakes up and sends a pulse to the cmos 4026.
But wait you say the 4026 is a up counter so how is it counting down. It's not I used a sneaky bit of programming to trick it ( a simple for next loop )
That bit of code in the 3rd user manual to run a 7 segment display is all I used to go up or down. It simply wipes out the number and puts new number in but looks like it counts down as well as up.
display_gear_routine:
pulsout 4,5
if b1 =0 then endclk ' if its a zero return
for b8 = 1 to b3 ' b3 holds the gear value
pulsout 0,5 ' pulse out to value to pin 0
next b8 '
endclk:
