I am trying to build a circuit which will test and fire pyro igniters (i know picaxe is not seen as a suitable micrprocessor for this type of job but this is not what i want to discuss here!)
when testing the mosfet is not 'switched' (in search for a better word) but the picaxe is using the 4016 to output one side and input the other side to read the adc value to see if the igniter is faulty. When a fire signal is sent the mosfet is fired.
The problem being, i have an idea for circuit design attached problems being:
1) current, the igniter needs over 200ma to reliably fire, i have a 500ma PSU so there is no worry, however, the 4016 will not be able to take that sort of current on its input/output (20ma max if i remember right). Therefore, using Mr ohms law i figure something like 1k resistor on each gate of the 4016 should be enough not to destroy the 4016 when firing.
2) protecting the picaxe, the resistor value would have to be worked out to stop anything happening from the drain to the picaxe but i am not sure how to work it out.
any help would be greatly appreciated, it has been a long time since i have used a mosfet!
Jon
Jon
