I want to use an SRF005 inside a water tank so it is going to be very damp. The board is no problem but the transducers must be exposed, does anyone know if the transducers on the SRF005 are moisture proof? I tried replacing the originals with a pair of Jaycar AU5550's on flying leads and while I could get some reaction, if the readings meant anything at all the range was only about 200mm. P.S. I replaced the originals and it works fine.
