Thanks for the reply. I'm attempting to gather together the appropriate reference material to work with the 20X2 chips.
Here are some items I've noted and still wonder about:
Pg 51 of Manual 1 appears to indicate that the 20X2 pins can be configured as either inputs or outputs - though you indicate they cannot be. Also the chip drawings for the 20X2 appear to indicate that several pins are used as either inputs or output.
Pg 74-77 of Manual 1:
Appendix A – BASIC Commands Summary
No PICAXE-20X commands or Additional Commands are listed.
Pg 98 of Manual 1:
Appendix I - Advanced Technical Information and FAQ
Can you alter the input/output pin arrangement of the PICAXE microcontroller?
The PICAXE-08 has 5 pins that can be configured as desired. The 28 and 40 pin PICAXE can also be altered to give more inputs or outputs. The 18 pin input/output pin arrangements are fixed and cannot be altered.
There is no mention at all of 20 pin parts.
Thanks in advance for clarification. I'll get this figured out yet.
