BobMcNobby
Hi Peter, I have looked into the Galvo idea, I couldnt find any cheap galvo's and since servos were going to be too slow I opted to reinvent the wheel but on a much smaller scale, the idea being "if the PCB is small and light it could mount anywhere !", I was thinking of attaching it to the end of a guitar or something similar
Also new ideas being explored :
PAN - Make the PCB circular and mount 3 motors equispaced at the periphery. mount them pointing down but at a slight angle out, then place the PCB on something round so that the 3 motors (with silicone sleeving on shaft) drive round the top of the round object. this will give 360 degrees continuous rotation
TILT - mount a third (larger) square mirror at an angle to the beam output which is on a pivot and drive it by a tiny motor. may get up to 60 degrees tilt out of that
I am also looking into 1-wire bi-directional H bridge to drive motors, there is probably something on here about that
Bob
Bob
