Hi there, first post in a while, and first post without "OT" in the title in an even longer while.
First off, I'm at uni so time is scarce to say the least. With the Xmas hols coming up soon, I want to get this project planned and ready.
Second; you might want to get a coffee/tea/stiff drink ready, this is long (or not bother reading it at all!).
I have a project and some ideas on how to do it. However, it's reasonably expensive, so before I go buying everything in order to make it, I'd like to run it by the guys who know everything (which will hopefully include every necessary detail about the project by the end of this post).
The current situation: I have a guitar with a built in effects pedal. This pedal has 5 controlling POTs and a bypass switch. Currently, I have easy access to the bypass/engage switch and two of the 5 POTs so I can change these with relative ease while playing. The pedal is turned on and off when a jack is plugged into the guitar.
Side note: The guitar also has two other things built in, a sustainer (one of the pick-up coils becomes a driver coil to drive the strings indefinitely) and a special set of pickups. Currently they run off two separate (common ground) 9V batteries. The sustainer (uses up a 340mAh battery in about 3 hours) runs off one battery; the rest (barely any current draw) runs off the other battery. However, the sustainer circuitry senses when a jack is plugged into the guitar (the tip of the jack breaks two contacts) and then grounds all the other devices' grounds to the common ground, effectively turning on all the other systems. The two 9V batteries can be easily removed (picture) and put in a charger to recharge.
What I want to achieve:
EDIT: Missed an item from the list: I want to still be able to use the guitar as an ordinary electric with any amp with any cable.
1. I want to be able to control all the dials and switch on the fuzz factory via MIDI. During performances I control various effects boxes using my computer using a USB/MIDI interface. I would like to be able to do the same with the fuzz factory. It would also mean I can effectively "save" settings which would be invaluable for this pedal; given a small difference in (just touching sometimes) a particular dial can have a huge effect on the sound. Also, lots of setting combinations sound terrible, but a select few sound fantastic.
I would want to have MIDI control of the bypass switch DURING performances, so for example during a verse the FF (fuzz factory) is bypassed, then when I get to the chorus it turns itself on. However, I wouldn't need the dials to be MIDI controlled DURING a song, only changing settings BETWEEN songs. However, there are two dials that I, physically, would want to be able to change during a song (the two I can currently control).
As for bypassing and engaging the FF pedal itself, the only way I can think to do this is using a SPDT relay?
2. MIDI touch pad (yes I'm a MUSE fan). This isn't an immediate need but something I would definitely plan on doing at some point, if not during Christmas. It's quite a simple concept. A resistive touchscreen is fitted to the guitar, the position of a finger is read as X,Y coordinates. The values of the coordinates are used as MIDI inputs, like a foot pedal position. So, it allows two parameters to be controlled. This would be used live, during a performance, so it needs to be fast (more on that later). It would also need to have two modes. Firstly where the last touched position is "held". That is easy enough to achieve as it just means X,Y values be continually send until the touch pad is no longer touched. And secondly, where the values "fall" back to zero when the finger is released. Also easy, just send (0,0) when the finger leaves the pad. I would also like it if it had some LED's behind it to make it glow (RBG). Also, the touch pad assembly needs to be completely surface mount. This shouldn’t be too much of a problem. The screen is dead thin and I can have its circuitry in the back with the other circuits. No extra routing should be needed. This is a video which has a good demo of the real thing. Skip to about 1/2 to just see the bit about the touch pad.
3. Change the batteries. I'll probably handle this one. I intend to put eight 1.2V 1200mAh NiMH batteries in place of the current 9V ones. Just so you know what kind of power supply we'd be dealing with.
4. Wireless. (Oh no!). Yes it would prefer it if the MIDI data exchange were wireless. My reasoning is actually pretty simple (aside from it being "way cool"). I currently use a normal audio cable coming from the guitar, that isn't wireless yet. However, if the MIDI data exchange were wired, I would need TWO more cables running from guitar to effects unit/computer. This is because it would have a MIDI input (touch pad) and MIDI output (FF controls) so, if done in a wired manner; it would need two separate MIDI cables to send and receive the data. I could reduce this to one cable where that cable has a PICAXE at each end talking to each other, but that is still too many cables for my liking. So this leads to the question of what wireless method. IR would just be too dodgy. Anything blocking a direct line of sight (e.g. me if I'm facing the wrong way) would disrupt it. Obviously it would need and RF solution. There are many to choose from though and I have never done any before. The criteria for the wireless devices are:
- It can exchange data fast enough to keep track of the MIDI touch pad.
- It must have 100% reliability. If a transmission to bypass the FF at some point during the song got lost, it would spell disaster.
- It needs to have good range. 10m range would be good, >30m would be better.
- It needs to be small. Conditions in the guitar are pretty cramped. I'm going to be moving stuff around inside it to make more room. I'll attach some pictures at the end to show what I've got to play with.
- Obviously, the closer the price is to free, the better.
