Heyah,
Im tring to simulate something in ISIS, and when it assembles my code I get an error "Memory location already used!". I ve searched it, and the only results I get are from these forums, only with 18X chips, but no one seemed to give a solution.
Any clues?
I ve tried commenting out complex-ish lines of the code seeing if that would affected it, but with no success.
just in case, this is my problematic code: (It works on a real picaxe):
Any clues?
initLCD:
pause 500
serout 1,N2400,(253,3,"Enter Password: ")
serout 1,N2400,(253,1,"T C LL ")
serout 1,N2400,(253,2,"Timer= s ")
serout 1,N2400,(253,4," INCORRECT ")
serout 1,N2400,(253,5," PASSWORD ")
serout 1,N2400,(254,1)
pause 10
security:
b0=0 'Initialize variables
b1=0
b2=0
b3=197
b4=0
serout 1,N2400,(3) 'Display "Enter Password: " on the LCD
pause 10
for b2=1 to 4 'Initialize the password entry loop
securityunderscore:
b3=b3+1
serout 1,N2400,(254,b3,"_") 'Display an entry prompt "_" accounting for LCD cursor position
b3=b3-1
bit5=0 'Reset bit5 (bit 5 adjusts "_" position)
securityentry: 'Entry of password
if b1>155 AND b1<172 then 'If backspace pressed delete last character
gosub securityback
readadc 2,b1 'Check password input switches
loop while b1<20 'Loop until there is an input
securityselectcase:
select case b2 'Compares input against the correct input, bit marked if input is correct
case 1
if b1>60 AND b1<80 then 'Range provided for relability
bit0=1
case 2
if b1>80 AND b1<100 then
bit1=1
case 3
if b1>100 AND b1<120 then
bit2=1
case 4
if b1>120 AND b1<135 then
bit3=1
endselect
b3=b3+1
serout 1,N2400,(254,b3,"X")
next b2
readadc 2,b1
bit5=1
goto securityentry
else if b1>135 AND b1<155 then
exit
loop while bit6=0
if b0=%00001111 then
setint %10000000,%10000000
pause 10
serout 1,N2400,(1)
pause 10
serout 1,N2400,(2)
pause 10
high 0
serout 1,N2400,(4)
pause 10
serout 1,N2400,(5)
wait 5
serout 1,n2400,(254,1)
serout 1,N2400,(1)
low 0
goto security
securityback:
if b2>=2 then
serout 1,N2400,(254,b3," ")
b3=b3-1
b2=b2-1
if bit5=1 then
goto securityunderscore
b3=b3+1
b3=b3-1
goto securityentry
if input6=1 then
w6=0
serin 1,N2400,(51),b1
if b1<10 then
serout 1,N2400,(254,131,"00",#b1)
else if b1<100 then
serout 1,N2400,(254,131,"0",#b1)
serout 1,N2400,(254,131,#b1)
pause 10
readadc 0,b2
b2=b2*100/255
if b2<10 then
serout 1,N2400,(254,137,"00",#b2)
else if b2<100 then
serout 1,N2400,(254,137,"0",#b2)
serout 1,N2400,(254,137,#b2)
pause 10
interrupt:
inc w6
if w6<10 then
serout 1,N2400,(254,198,"00",#w6)
else if w6<100 then
serout 1,N2400,(254,198,"0",#w6)
serout 1,N2400,(254,198,#w6)
pause 10
setint %00000010,%00000010
