Re the "earth symbol" on the previous posting website link, with a dual rail power supply that does connect to earth but not many people use dual rail supplies. With a single rail supply, it is usually connected to 1/2 the supply volts - eg for a 5V supply, to 2.5V. To make 2.5V use two resistors. But the value of these resistors needs to be a lot less than the input resistor of the differential amplifier. 1K would probably work, but if you use 10K ones and run it through a voltage follower the reference voltage is more stable. Then, it is a simple matter to replace the two 10K resistors with a trimpot of any value from 1K to 1M. Hope this makes sense and hopefully I will work out how to do ascii art that is wider than the input text window!
