SilentScreamer
I need to measure a voltage between 0V and 0.05V (or even less if possible). I have a 12 bit ADC that I plan to use if the final project although I'll use the PICAXE's own 10 bit until I get it working, I could resort to 8bit if it isn't possible to amplify with enough precision. Is it possible to use a Op Amp (or anything else) to multiply the voltage to 0V-5V? If so what terms can I search for to find an example circuit to adapt? I've been searching for the last couple of days with little relevant information found (though its probably my searching ).
It is not important if it is not multiplied linearly as I plan to do the maths using a PC (via serial) rather than on the PICAXE.
Thanks in advance,
SS
Thanks in advance,
SS
