Hey Guys,
I do apologize for this isn't a direct Picaxe Question, although I have 2 20x2's on my Board. But I was wondering if you could help me out.
I built a little demo board using 2 x 20x2 and a RS232 Driver. I was using a Linear regulator but unfortunately it was getting to hot and I decided to switch to a Switching regular direct replacement (7805). The new one is a Recom R-78E5.0-.5 500mA. My circuit only draws a maximum of 200 mA.
The problem I am having.. Is I have 2 devices plugged into the MAX232 Driver which are independently powered with there own supply. If I remove 12VDC from my board and leave the devices plugged in to the MAX232 chip I am getting Negative .283 Volts on the output pin of the Switching regulator. The switching regulator will not turn on because of this. When I apply power to board the regulator will not turn on. If i remove the MAX232 connections RX/TX from each device then power board the regulator kicks right in.
Is there a simple way I can fix this issue other then putting a separate small linear regulator at the MAX 232 to isolate it from the system? If I remove one of the Pairs of RX/TX the voltage drops to negative .163 and the regulator will then turn on about 50% of the time. I have checked and re checked the schematic..
Thanks for any input you can give me.. I have googled it all day and cant seem to find anyone with the same issue. I tested a couple older boards I have with different makes and model of MAX232 chips and they all do the same Negative .163 volts . This new board is the first one I have made with 2 x RS232 connections so its doubling the negative voltage causing this.
Steve
Steve
