Jeremy Leach
This is just a pretty abstract idea to kick around ...
I like the challenge of getting the most out of limited resources, so was thinking: Could have an 08M (8 pin) and a 24LC512 EEPROM (8 pin) side by side on a 16 pin DIL forming a 16 pin logical 'device'. The EEPROM holds 'code' and the 08M holds a simple interpreter to run the code.
Ok, the idea of interpreting from EEPROM is not new and has been discussed before, but here I'm just wondering about the idea of maximum functionality from a picaxe system using the minimum of physical space. i.e what gets me is that with 64K bytes of 'code' on the EEPROM, it might be possible to do some quite amazingly complex things, even though it might be very slow. And there might be some apps where speed isn't the issue, and where this might actually be useful. And before anyone says 'just try it' I don't even know what to try ....it's just to see if anyone could think of any uses
