So the situation about the problems I talked about in my recent post about the AxeStack have clarified a little.
Just an update: the Axe027 cable was working normally on my computer, and then for no reason that I can detect (i.e. I made no changes to the computer setup - all I really did was install a new circuit...), every attempt to program was met with a "Hardware not found" error - even just clicking on the "firmware" button in the "mode" tab on MacAxepad yeilded the same error.
At first, I thought it was the PIC, or at least the programmer board, but I took a NEW apple mac, and installed the Axe027 sofware on that, without attempting to program anything, and simply plugging the cable into the USB port, and used MacAxepad to check the cable firmware (without plugging into a chip, board or anything) and it reports that it CAN find the hardware (note that there seems to be some nomenclature confusion between "firmware" and "hardware"...?).
In any case, the result is this - the cable WAS working on my computer, and I am quite sure that I did nothing to modify the system, and then it stopped. However, it DOES work on a different computer. So the problem has to do with my own setup - but I've not changed anything, so I don't know where to start to try to diagnose the problem?
Any hints would be appreciated.
My computer is a Macbook, running OSX 10.5.6
the firmware in the Axe027 cable is ver 8.8
Thanks.
Emuller
Thanks.
Emuller
