titaniumnitratecoatedcow
hi
my code involves cars entering a beam and then variable b3 count up only once the car exits the beam.
currently i am using two sub routines that have to happen in order to get b3 to count up(in_the_beam and out_of_the_beam).
i was wondering if there is a simpler way of getting this to happen:
1) the beam is broken
2) the beam is unbroken
if both of these things happen get b3 to count up
here is my code, thanks for an help available
init:
b3=4
pause 500 ; wait for display to initialise
serout B.1,N2400,(254,1)
pause 30
serout B.1,N2400,(254,128) ; move to start of first line
serout B.1,N2400,("places availible") ; output text
irout b.2, 1, 16 ; Send the command
'pause 45 ; Pause after each command sent
readadc b.3,b1
debug
if b1 <50 then goto in_the_beam 'the car needs to be in the beam, but the exit the beam for b2 to count down,
'otherwise a car could sit in the beam for too long and cause multiple spaces to be displayed as taken.
'if b1 >50 then
serout b.1, n2400, ( 254, 192 ) 'second line
'pause 500
serout b.1, N2400, (#b3)
in_the_beam:
readadc b.3,b1
pause 500
if b1 >50 then goto out_of_the_beam
goto in_the_beam
out_of_the_beam:
let b3 = b3 -1 ;the car is now out of the beam so display one less space as available (count up from 4)
if b1 < 50 then goto in_the_beam
if b3=0 then goto full 'stop b1 from counting up (maximum spaces taken up)
full:
let b3=4 'stop at 0
serout b.1, n2400, ( 254, 128 ) 'second line
serout b.1, n2400, ( "park is full " )
[code]
