Hi. Advice needed. Currently I making wind turbine project. My wind power generator is almost ready to go and to avoid cable wraping around the pole I want to make construction be able to control wind turbine direction. At the moment I am working on absolute encoder and I'm thinking of using two of them. One is for knowing direction of wind (weather vane) and the other for knowing the direction of the wind turbine. I decided to make an absolute 4 bit gray code encoder, but I wouldn't like mechanical one, as I want friction free. 4 bits must be switched on/off or blocked/unblocked opticaly depending on encoders shaft possition. The problem is, I am not sure how shall I make 4 optical sensors, what connection diagram shoud it be or shall it be infrared emiters, collectors, or LED lights or any other way it's possible to make the task with picaxe. Any suggestions guys?
Thanks for your help.
