Using MacAxepad 1.1.0 on 12" mac powerbook under system 10.5.8, attached to large monitor (1920x1200 pixels). Works fairly well, except that if I drag editor window to be longer than around 700 or 800 pixels (about 60 lines of code at courier 12pitch) in one go, the editor regularly crashes. If I enlarge window really slowly, or in several successive drags, it seems to get to full length (around 80 lines of courier 12 code) without crashing and then works ok. I can work around this, and it may reflect a peculiarity of my system, but was wondering if perhaps the editor was not really designed to work reliably with windows over 768 pixels vertical or something. I had the same problem but much worse under system 10.4, to the extent I had to use the regular editor on a Windows machine. The initial part of Apple crash dump shown below. Anyone have similar experience or insight? Thanks.
Process: MacAXEpad [301]
Path: /Applications/MacAXEpad.app/Contents/MacOS/MacAXEpad
Identifier: ???
Version: (1.1.0.3.271)
Code Type: PPC (Native)
Parent Process: launchd [149]
Interval Since Last Report: 413 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 50 sec
Per-App Crashes Since Last Report: 1
Date/Time: 2010-08-24 13:18:36.788 -0400
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: 8DDF8F69-BA92-4BF1-A392-D9A29241A1A8
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000001c
Crashed Thread: 3
Identifier: ???
Report Version: 6
Crashed Thread: 3
