Good Tips
Hi Guys, Some very good tips here. To answer:
I guess this really is a prototype. Well i have two in service with 0-5V transducers i bought cheap on eBay, and these were 20bar transducers and it turns out the pressure won't go above 3 bar. That's about 45 PSI in old money, so we are talking about between car and bicycle tyre pressure. Its not high. These transmitters are 4 bar, the correct range for the job, and this will be my first signiificant mod to what has been installed.
Using the 4-20 mA transmitter (transducer plus 4-20mA mitter) does seem to be a standard for industrial process control and PLCs. By selecting the appropriate resistor eg 240 ohm i can detect less than 4 mA and greater than 20 mA, therefore open circuit or dead short, the only two options with two wires, and i can flag this up on the LCD and Logomatic data Logger as a maintenance action. (This is for monitoring, not control) Although Westaus, your comment about 22mA has thrown me i naively thought they just went to 20 mA.
These particular Sensors also from Ocean Controls who were best priced
http://www.oceancontrols.com.au/Sensors/pressure/pressure_gs4200.htm and cheaper than RS components for the same thing (if anyone knows a cheaper source, tell me) and according to thhe data will operate from 13-36V.
The mining machine has 24V, but who knows how stable and erratic that is, so the idea was to take the 24V, use a 15V 1A fixed regulator ($1.20) and the proper capacitors for filtering, and power the transducers from that. The 15V would also be the Vin for my prebuilt microprocessor module. This is just to make the whole electrical thing more stable. The module and and prototype board from
www.modtronix.com.au, and i have added the Picaxe download and reset circuit (have photos). Using Picaxe 28x1 in the SBC28 board, with the protoboard with 24 connecting points, so i can connect all the remote transducers and DS18B20 temp sensors easily. I2C for the LCD is via separate mini match connector, makes it easy and nice and modular.
I have been using screened microphone cable from
www.Jaycar.com.au, WB 1540 four wire, but if i only have two wires i was going to use the two wire version. It is tough, and at about $2.50 per metre it is pretty affordable. I tried cat 5 cable for temperature sensors, but is so light it is a pain to work with. The microphone cable is chunky, more mine proof. One benefit of using 4-20 mA rather than voltage signals is meant to be signal stability.
Retro, good points about transducer placement, thanks. The fluid is hydraulic oil, and the purpose of the whole project is measurement in a fluctuating flow condition. It is possible for air to get in the system because the measurement is all on the low pressure side of the hydraulic circuit so i take the point about positioning the transducers so there are no air bubbles caught in there. On one of the machines it is upside down, (correctly) because that's how it turned out on the day, but the second is definitely catching air bubbles which will be dampening the pressure response. Need to fix that.
Hope that answers the questions. Advice welcome.
Forum seems to be 50-50 on whether the zener should be there or is optional. I'm still having trouble seeing if it is necessary. Even in dead short at 24V, only a couple of milliamps could squeeze through a 10K resistor prior to the ADC input. Is a few milliamps going to be a problem on this Picaxe input?
This "high " voltage is going to be the "Short Circuit" indicator ( if volts greater than 4.8 then alarm) so putting the zener there will take away this desirable feature. Zeners are not that precise that i can rely on the voltage (learned this from previous thread). I want this high voltage indicator without losing significant range on the adc input.
I do plan on pressure testing (with a bike pump) before the thing is installed next week.
Regards,
Michael
