Hi
I am trying to produce a 60hz (with a tolerance of 30hz) sqaure wave 0-5v output from my 40X1 chip to run an LCD. I need to run the rest of the programe at the same time so was planning on using the pwmout but I do not seem to be able to produce a PWM less than 4 khz.
I have 3 questions.
(1) Is it possible to produce less than 4khz PWM with the pwmout?
(2) If you use a pause or wait command does this stop the rest of the programme from running until the pause or wait have completed?
(3) Does anyone have another solution that will not stop the programme from running and will give a consistant output?
Thanks
I have 3 questions.
Thanks
