I am looking for pointers on the attached code. I feel I have learned a lot by researching this forum and some of you will surely see code snippets of yours here. But for better and I'm afraid worse I will take responsibility for this code in its entirety. Am looking for areas to improve, other coding techniques that could be used and would like to know if there is a slicker way to handle the if...then section of code at the bottom.
Thank you to everyone who contributes to this forum for getting me this far.
#PICAXE18m2
symbol VSL = 2 ;Variable Start Location (ie, b2)
symbol VEL = VSL + 6 ;Variable End Location (# of variables)
symbol VLOS = 30 ;Variable Location OffSet amount
symbol LSP = VSL + VLOS ;Loop Start Position
symbol LEP = VEL + VLOS ;Loop End Position
symbol Sc = b2 ;Seconds from DS1307
symbol Mn = b3 ;Minutes from DS1307
symbol Hr = b4 ;Hours from DS1307
symbol DOW = b5 ;Day of week from DS1307
symbol DD = b6 ;Date from DS1307
symbol MM = b7 ;Month from DS1307
symbol YY = b8 ;Year from DS1307
hi2csetup i2cmaster,%11010000,i2cslow_8,i2cbyte ;Set PICAXE as Master with DS1307 as Slave at address
hi2cin 0,(b2,b3,b4,b5,b6,b7,b8) ;Read time & date into variables (BCD format)
for bptr = LSP to LEP
lookup b0,(Sc,Mn,Hr,DOW,DD,MM,YY),b1 ;Loop through time & date values
b1 = b1 / 16 * $FFFA + b1 ;Convert BCD to ASCII
bptr = bptr - VLOS ;Calculate RAM location
poke bptr, b1 ;Poke variable value to RAM location
bptr = bptr + VLOS ;Reset RAM location to continue loop
inc b0 ;Increment lookup value
next bptr
if DOW = 1 then sertxd ("Sun") ;Convert Day of Week number (1-7) to text
elseif DOW = 2 then sertxd ("Mon") ;Convert Day of Week number (1-7) to text
elseif DOW = 3 then sertxd ("Tue") ;Convert Day of Week number (1-7) to text
elseif DOW = 4 then sertxd ("Wed") ;Convert Day of Week number (1-7) to text
elseif DOW = 5 then sertxd ("Thu") ;Convert Day of Week number (1-7) to text
elseif DOW = 6 then sertxd ("Fri") ;Convert Day of Week number (1-7) to text
elseif DOW = 7 then sertxd ("Sat") ;Convert Day of Week number (1-7) to text
sertxd (#Hr,":",#Mn,":",#Sc,cr,#MM,"/",#DD,"/",#YY) ;Write out string to screen
pause 7000
