Why are we (you
) getting hung up on ancient/obsolete/hard-to-find devices?
Granted that without a schematic or block diagram it's difficult to make proper suggestions but consider the following.
1. Go to Farnell/RS Components/Digikey and do a PARAMETRIC search.
At least it'll give you some options on current (pun) devices.
2. Many regulators can work with pass tranistors.
You may have seen an on-line circuit but do more searching on designs. Don't get stuck on one design.
But please be aware that it will get chuffing hot and I'm not sure your box will sink adequately.
3. Look at switcher designs unless there is some specific reason to avoid them.
The extra bit of noise may or may not affect your downstream circuit. Check.
Your component specification and circuit layout will make a big difference to performance.
4. Consider Switcher control ICs plus a suitable external transistor.
Similar caveats as above.
5. Think about a Switcher doing the bulk work and a linear hanging on the end to fine-tune.
Some noise will still sneak through. Don't imagine a linear will get rid of the noise totally.
6. A DIY Switcher using PWM , maybe with a linear at the end.
There are many options. Please don't get obsessed with a single design because that was the first one you found on some site.
Switchers were 'made' for this type of job unless noise is a problem.
