This thread refers to the thread here:
http://www.picaxeforum.co.uk/showthread.php?t=10039&highlight=battery+charger&page=22
BCJkiwi and Wapo both got the circuit working so I'll attempt it next. However, I want to employ a 28x1, running at 8MHz so as to (maybe) include a matrix keypad READADC for setting required voltages etc. The problem is that the available current is somewhat low, 1.5 and 3 Amp for the two mentioned regulators.
Will this work with a PNP Pass Transistor (as is placed across the 78xx series) in order to increase current capacity to say 6 - 10A ?
Is "doubling-up" as per the regulator datasheets possible to increase current ?
Will the 28x1 at 8MHz be quick enough to read analogue keypad value inputs while maintaining voltage ?
I see that BCJkiwi states that once the required voltage is reached on the output it remains stable. Will this then make it possible for the 28x1 to perform other tasks such as RS232 comms with the Firmware chip for LCD updates etc ?
Just some questions (still) on the circuit from a VERY long original thread...
