Taken from other thread:
BB: I only have a candle and so have tried with that (have a huge red/green "blind spot" in my eyes) but this stuff is weird.
I've soldered litz before once, but this stuff is different. Usually, the nylon melts away, and the enamel burns of in the solder. The soldering iron has no effect on the nylon, however the candle does, so that is no longer a problem. I assume the idea of the flame is to get the wire hot enough for the solder to stick to. Instead, the wire goes black (even after being carefull not to hold it IN the flame) and the solder WILL NOT stick.
I also don't have a solder dipping pot or any flux. I do have flux cored solder though so I've been making a ball on the soldering iron and using that with no success.
The black seems to be soot though and when scraped off, I can get a connection on the wire, but still no luck getting solder to stick...
I usually file the end, and then coat it in solder to give a good connection.
A
Andrew: that is what I'd normally do, but this stuff is a nightmare.Hold with pliers leaving about 1/4" free.
Apply flame from cigarette lighter until copper glows.
The pliers prevent heat travelling down the wire.
Then dip in flux and solder.
If you don't have any flux, then gently scrape scalpel after the flame treatment.
Don't breath the vapours!
