Good Evening everyone,
I'm making a little project, pretty simple, its a LED light for underwater.
The LED cobs are going to be reasonably powerful, Im looking at the Cree LED CXA2540-0000-000N0HV250H, XLamp CXA2540 White CoB LED, 5000K
I want to add a Thermal Couple to the LED on the TC solder point, and monitor via a Picaxe. Couple of questions,
1) What type of TC should I use with a Picaxe?
2) What would be the best way to link the Picaxe TC circuit to the power supplier to throttle the power should the LED temp get to high?
I want to power a total of 4 lights, which I calculate as 75w each, so 300w total.
Im thinking of using either 4 of these - Mean Well LED Driver, 36V Output, 75W Output
or 2 of these to power 2 at a time - Mean Well LED Driver, 36V Output, 150W Output, 5A Output
Do these drivers seem suitable?
Another option I was thinking was, could I run all 4 off a PSU like this - AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 320.4 W, 36 VDC, 8.9 A
Many thanks in advance
RH
RH
