trevorboultwood
Well I am still waiting for the transistors for my matrix but I have gone back to another project to make it better.
My other project was a little project which was when you called a number it flicked a relay and turned on my computer and opened all the servers. I needed to use remote connection the other day and I found out that you need a password to be able to do that... (O edit the registry but I love electronics!). So now I was going to create a password e.g. 123 and then get the pick to activate a transistor on a keyboard.
After taking apart my keyboard I found out it uses plastic, this is where I started knowing this may be a little hard to do. SO I have been following the tracks for each number. It has been going well and I have successfully done the first two letters. But when it came to the next key for some reason I am getting really confused because it isn't doing anything! I could just change the password but then, that isn't the point.
I then remembered seeing a section in the manual about interfacing a keyboard with a pic... But here is the question, can I send a signal to the computer with a picaxe?
I haven't seen any circuit diagrams and the keys are o l I b a e s n (mixed up because I use it for many accounts ) But can I do this? Thanks to all!
