Having got my CMPS03 re-calibrated manually (no luck with the i2c method)
I have assembled the CMPS03 into a small plastic box, mounted on the inside top with nylon nuts and bolts.
On the cover of the box, I have assembled a circle of 16 LED's as a form of simple visual heading indicator. These LED's are controlled via two PCF8574 8-bit IO expanders - each controlling 8 LED's.
Tonight, I have successfully written a short program to drive the 16 LED's in 32 steps corresponding to the compass heading. Again I have used a maths based scheme (akin to my earlier bargraph logic) rather than the look-up table in EEPROM as often done.
Attached is a diagram showing how the LED patterns are used for 32 steps with a resolution of 11.25 degrees and below is a sample of the code I wrote to drive the LED's.
hmmm, I guess a Nokia 3310 graphic LCD screen would also make a nice compass heading display as well - likely even better angular resolution as well. Food for thought and future projects here.
; File....... CMPS03 LED heading Indicator Test
; Purpose.... test operation of the set of 16 LEDs via i2c comms
; Author..... Westaust55
; E-mail.....
; Started.... 02-07-2008
; Updated.... DD-MM-YYYY
; -----[ Program Description ]---------------------------------------------
; A program to test operation of the set of 16 LEDs mounted in a circle
; as a visual heading indication for use with the CMPS03 cpompass module
; using i2c comms
; -----[ Revision History ]------------------------------------------------
; First coding
; -----[ I/O Definitions ]-------------------------------------------------
; -----[ i2c Devices ]-------------------------------------------------------
; PCF8574 8-BIT IO EXPANDERS
SYMBOL expand_0 = %01000000 ; %0100 = Chip ID, 000 = Addr 0 - For the 8 Red LED's
SYMBOL expand_1 = %01000010 ; , 001 = Addr 1 - For Keypad Shift LED
SYMBOL expand_2 = %01000100 ; , 010 = Addr 2 - For Compass LED display right half
SYMBOL expand_3 = %01000110 ; , 011 = Addr 3 - For Compass LED display left half
; DS1338 REAL TIME CLOCK with 56 bytes of RAM
SYMBOL rtc1338 = %11010000 ; %1101 = Chip ID, 000 = hard addr
; -----[ Constants ]-------------------------------------------------------
; -----[ Variables ]-------------------------------------------------------
SYMBOL delaytime = b22
SYMBOL pattern = w10
SYMBOL pattrn2 = w9
; -----[ EEPROM Data ]-----------------------------------------------------
; -----[ Initialization ]--------------------------------------------------
Init: delaytime = 500
; -----[ Program Code ]----------------------------------------------------
Main: HI2CSETUP i2cmaster, expand_1, i2cslow, i2cbyte ; Set up for 9th LED
HI2COUT (0) ; SHIFT LED off
PAUSE 500
HI2COUT (1) ; SHIFT LED on - just blink LED on and off
PAUSE 1000
PAUSE 500
HI2CSETUP i2cmaster, expand_0, i2cslow, i2cbyte ; Set up for set of 8 LEDs
HI2COUT (255) ; turn on all LEDs for 1 second
PAUSE 1500
HI2COUT (0)
PAUSE delaytime
; the above line of code are just to turn of the LED's for the bargraph and keypad shit key
; these LED's use positive logic (1 = ON, 0 = OFF) done by adding a transistor to the expander outputs.
; the LED's for the compass heading are wired and using inverted logic
; hence the INV command at the start of the shwpattn subroutine below.
circle: FOR w4 = 0 TO 359 ; degrees in circle
w5 = w4 * 10 ; this is equal to actual reading will get from CMPS03
w2 = w5 * 10 + 562 ; adjusted value 562 = half of the 11.25 degree resolution as offset
w2 = w2 / 1125 AND 31 ; divide by 11.25 deg reolution for step 0 to 31 and rolling over to 0
b6 = w2 / 2 ; bit position for the first LED posiiton 0 to 15
b7 = w2 // 2 ; when b7 = 1 means the 2nd LED is required
IF b7 = 1 THEN
b7 = b6 + 1 ; get the corect bit position for the 2nd LED
ENDIF
pattern = DCD b6 ; 1st LED is encoded here
IF b7 > 0 THEN
pattern = DCD b7 OR pattern ; add/or in bit position for second LED when it is required
ENDIF
GOSUB shwpattn ; now display the correct LED pattern
PAUSE 100
NEXT w4 ; advance to next degree of heading
GOTO circle ; and go around again and again
; END
; -----[ Subroutines ]----------------------------
shwpattn: pattrn2 = INV pattern
HI2COUT [expand_2], (b18) ; pattern for right side of LED indicator
PAUSE 10
HI2COUT [expand_3], (b19) ; pattern for left side of LED indicator
RETURN
; -----[ Interrupt Routines (if used) ]-----------
;Interrupt:
; RETURN
; THE END
