Learning to Drive an LCD DISPLAY
marks
Blame ! Saborn for this Thread he pointed out those cheap LCD's on ebay
I just couldn't resist those blue ones lol.
Going to start a project where i can use 1 so it was about time I learnt how to drive it !
seems quick enough dont think i'll need a serial driver again lol.
''         COMMAND SUMMARY
'senddata = $38 : GOSUB Command             '(56) Function 8bit/2line/5x8
'senddata = $01 : GOSUB Command             '( 1) Clear Display
'senddata = $02 : GOSUB Command '           '( 2) Cursor Home
'senddata = $07 : GOSUB Command '           '( 7) Character Entry Mode
'senddata = $08 : GOSUB Command '           '( 8) Display Off
'senddata = $0C : GOSUB Command             '(12) Display On/Restore Cursor Off
'senddata = $80 : GOSUB Command	        '(128-147)  Line 1 Cursor Position ($80 + 1 to 19)
'senddata = $C0 : GOSUB Command	        '(192-211)  Line 2 Cursor Position ($C0 + 1 to 19)
'senddata = $94 : GOSUB Command	        '(148-167)  Line 3 Cursor Position ($94 + 1 to 19) continuation of line 1
'senddata = $D4 : GOSUB Command	        '(212-231)  Line 4 Cursor Position ($D4 + 1 to 19) continuation of line 2
'senddata = $0D : GOSUB Command '           '(13) Blinking Cursor
'senddata = $0E : GOSUB Command '           '(14) Underline Cursor
'senddata = $10 : GOSUB Command '           '(16) Move Cursor Left
'senddata = $14 : GOSUB Command '           '(20) Move Cursor Right
'senddata = $18 : GOSUB Command '           '(24) Shift Display Left
'senddata = $1C : GOSUB Command '           '(28) Shift Display Right
	#picaxe 20X2
	#no_data
	#terminal off
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
'            DB3  = B.3
'            DB2  = B.2
'            DB1  = B.1
'            DB0  = B.0
	SYMBOL E    = C.7
	SYMBOL RS   = A.0
	SYMBOL senddata  = b0
	SYMBOL index     = b1
	SYMBOL D1       = b11 'minutes
	SYMBOL D2       = b12 'minutes
	SYMBOL D3       = b13 'seconds
	SYMBOL D4       = b14 'seconds
	SYMBOL D5       = b15 'tenths
	SYMBOL minutes  = w10
	SYMBOL seconds  = w11
	SYMBOL looptime = w12
	TABLE  0, ("marks  ")
	TABLE 16, ("PICAXE 20X2 LCD")
 	dirsB = %11111111
 	dirsC = %10111111
Intialise:
	FOR  index = 0 to 2                            ' Initialise LCD
 	NEXT index
CountTIMEofLoop:                                    ' just for fun
SETTIMER 62411
TIMER = 0
Main:
FOR looptime = 1 TO 100
minutes = timer/600
seconds = timer//600/10
bintoascii minutes,D1,D1,D2
bintoascii seconds,D3,D3,D4
D5 = timer//600//10+48
LCDdisplay:
      FOR index = 0 TO 6
 	  READTABLE index, senddata : GOSUB Display ' sending characters to line one
 	NEXT index
 	FOR  index = 0 TO 6
 	  LOOKUP index,(D1,D2,":",D3,D4,32,D5),senddata
 	NEXT index
        senddata = 193 : GOSUB Command	        '(192-211)  Line 2 Cursor Position ($C0 + 1 to 19)
  	FOR index = 16 TO 30
 	  READTABLE index, senddata : GOSUB Display ' sending characters to line two
 	NEXT index
NEXT looptime : end                               ' Display time of 100 loops of program (9.8seconds)
Command:
	LOW  RS					        ' set to command
	  outpinsB = senddata			        ' > send command to LCD
	  PULSOUT E,1                               ' \ valid data failing edge
	HIGH RS                                     ' set to character
                           RETURN
Display:
	  outpinsB = senddata			        ' > send character to LCD
                                    RETURN
Ive created a command summary where i can just cut and paste as required
havent tested all of of them yet but think they are correct.
The example program shows how we can display some text
and for fun included a counter so we can see some moving numbers.
The LCD module was a Bona 1602-18 # note the backlight was only 4.2v
I calculated a 10 ohm resistor but best start with something larger.
for contrast Vee i found 1.5k res works well.
Also tested the code on my Sure 4x20 LCD Display, interestingly that display
worked without any connection to vee(contrast).
Thanks ! nicka2ab
Always looking for useful comments.
When downloading a new program the LCD display will just be filled with characters,
on reinitialising we are Clearing the Display anyway.
it does tie up the S.0 pin i thought instead of displaying info on the terminal just doit on the LCD .
those who wish can easily change the pinouts of RS and E in SYMBOLS
* the main aim was just to display some info on an LCD without having to use a serial driver*
I may look lateron at pin configuration freeing up Hi2c and Hser pins
creating a serial driver does seem achievable just need to learn a few new commands lol.
I agree with nick12ab on moving RS to A.0, E to C.7
Not only avoiding garbage during download, but also allows DEBUG and/or SERTXD to be used when debugging a program without corrupting the display.
It also means you could use the project as a mini-terminal; serial to LCD plus button inputs or a keypad matrix on C.x with the data passed back via serial using SERTXD.
The loop in the initialization part seems a bit of an overkill and using gosubs for every byte to send to the LCD would have to be changed in speed critical applications.
Anyway, here's a schematic for the PICAXE-40X2 i you want to use it on that. Note that my LCD has Vss next to K rather than D7 next to K.
HIGH E
outpinsB = senddata
LOW E
RETURN
I'm never sure when a specific LCD updates the data on E ( rising edge, while high or on falling edge ) as I rarely read the LCD manuals unless something doesn't work. I recall having an LCD which changed the data whenever E was high which meant there was disconcerting update of the character as it was first changed to what was on the output pins when E went high before being set correctly.
It's easy to code so it doesn't matter whichever way the LCD works; set the data then activate the strobe -
outpinsB = senddata
HIGH E
LOW E
Or more simply ...
outpinsB = senddata
PULSOUT E,1
Because most writes will be Data bytes rather than Command codes, and a Command code is always sent first by the program the two routines can be optimised as -
Command:
LOW RS
Display:
outpinsB = senddata
PULSOUT E,1
HIGH RS
RETURN
That will also help ( in that there's only one place to change things ) if you wish to use the code on a PICAXE which doesn't have the full 8-bits of Port B available or does but some pins are used for other things (I2C, high-speed serial ).
A final note is on initialisation; sending three $38 command codes as is done in this program. While it often seems to work with a single code sent and it's tempting to optimise to that it's not a good idea.
Some LCD's have an amazing capacity to retain their memories long after power is removed so I'm guessing they are usually always in a previously initialised state and only one $38 does the job, but if powered-off and left a longer time, just one $38 doesn't always work and it needs to be power-cycled or the PICAXE reset to send another $38.
Once working an LCD keeps on working, but turn it off and leave it long enough then it may not initialise when turned on again which is confusing to say the least. Best to simply send three $38 and have done with it.
Note also that some LCD's specify longish time gaps between initialisation command codes sent. Again it often seems to work without but best to add them. Rather than worry about decreasing gaps simply send all with the longest gap time. It will still be quick on human time scales.
I Know Dippy,s often recommending to read the data sheet!
But there's really no point Hippys far better ! lol
I wasnt going to reply for a while until I had a chance to think about some changes.
but Hippy put too much effort in i thought i better respond.
changed the code and drawing slightly to add some of the suggestions
the program will now do 100 loops and stop and display a time on the LCD.
The high E and low E gave a time of 10.5 seconds
surprisingly using pulseout improved this to 9.9 seconds
and swapping a0 and c7 pins improved to 9.8 seconds lol thanks nick12ab
and i think two 20x2 are better than a 40x2 picaxe i wish i had 1
your other part of the code wasnt quite efficient it blew 10.6 seconds,
as the display has that extra high command in it.
I was not really concerned with speed as i thought around 10 updates a second was pretty good
it did make it interesting tho and now with the program set up this way makes it easy to see
the effects of different commands
as always thanks Hippy ! and thanks too nick12ab !
You can speed stuff up using the SETFREQ command on all X2 parts to up to a guaranteed 64MHz at 5v and still use PULSOUT E,1.
I don't see why the repeated sending of $38 is necessary
I thought Hippy explained things pretty well
from memory the datasheet shows an example
if the lcd fails to initialise during powerup
the lcd can also be initialised by software by the micro
using a sequence of 3 %0011xxxx
interestly its the same for 4 bit mode
so you start in 8 bit mode and set it to 4 bit mode.
Hippy, your now shut down LCD interfacing site has an error
Most LCD modules will have a single 14-way connector, and 16-way if backlit, and are normally numbered as shown, with Pin 1 being 0V ( or "Vdd" ).
You mean Vss don't you?
Repeated sending of the same number doesn't happen in your LCD interfacing page either.
using a sequence of 3 11xxxx
Which datasheet?
Yes, and that was corrected, but the site had grabbed a January 2005 version but they never copied the updated page.
http://galia.fc.uaslp.mx/~cantocar/microcontroladores/PICAXE/PICAXE_LCD_INTERFACING.HTM
It does, but it's not so obvious -
' Nibble commands - To initialise 4-bit mode
EEPROM 0,( $33 ) ; %0011---- %0011---- 8-bit / 8-bit
EEPROM 1,( $32 ) ; %0011---- %0010---- 8-bit / 4-bit
Because two E strobes are issued for every write ( ready for 4-bit mode later ) that actually sends (as an 8-bit mode LCD sees things ) -
%0011 0000
%0011 0000
%0011 0000
%0010 0000
Which datasheet?
I've got a paper printed RS Data Library datasheet from 1986 which I rely on for the 'worst case' situation as new controllers are likely faster and better but people will often be dealing with old recycled LCD's. I've attached a later PDF datasheet which still shows the three $3x initialisation sequence and timing on page 45 for 8-bit mode -
1) Power-On
2) Wait 15ms+ after +V is 4V5 / Wait 40ms+ after +V is 2V7
3) Send $3x
4) Wait 4.1ms+
5) Send $3x
6) Wait 100us+
7) Send $3x
8) Send $2x
For 4-bit mode it's on page 46 and is the same except for only sending nibbles. I actually violate the 4-bit timing in my code, don't have the 4.1ms pause between (3) and (5). That's noted in the page but it hasn't proven a problem for me yet.
I've just spotted that when the LCD +V reaches 2V7 that's effectively the same time as it reaches 4V5 in reality so for (1) I should perhaps delay 40ms rather than the 15ms I have in my code, however it 's worked so far with 15ms delay for (2) and (6). The PICAXE reset probably adds the delay which I'm missing anyway (25ms), and usually the LCD has been powered up for a while when the PICAXE is reset. Maybe I had considered all that or maybe I just got lucky :-)
It's always a problem trying to write truly generic code which will work with anything. It's relatively easy to make it work with what you have but harder to tell what is needed for what you don't have and may not even exist yet !
The original aim was smallest size LCD driver code and full compliance was sacrificed for the sake of it working with all the HD44780 I had and that seems to have been good enough for everything else anyone has thrown at it. I think there's been one case of it not working with some non-Hitachi controller and the configuration sequence may have had to be tweaked for a few other cases, but otherwise it's worked, even though not even fully compliant with Hitachi timing.
8 Bit / 4 Bit Shootout !
I thought it may be interesting to compare default speed 8Mhz
with 4Bit we seem to be able to achieve 6.5 updates per second
while 8Bit we get arround 10 updates (35% quicker)
<<4 is much quicker than *16
using | in place of + slight difference faster
As i'm impatiently waiting for my Blue Oled to appear on TECHSUPPLIES
decided to get a 18m2 to tryout penciling out a serial board
i can already see the 20m2 would be a much better option
But it will be interesting to use something similiar to what others seem to be using!
'         COMMAND SUMMARY 4 BIT MODE
'RS = 0 :senddata =   1 : GOSUB Send : RS = 4             '( 1) Clear Display
'RS = 0 :senddata =   2 : GOSUB Send : RS = 4             '( 2) Cursor Home
'RS = 0 :senddata =   8 : GOSUB Send : RS = 4             '( 8) Display Off
'RS = 0 :senddata =  12 : GOSUB Send : RS = 4             '(12) Display On/Restore Cursor Off
'RS = 0 :senddata = 128 : GOSUB Send : RS = 4        '(128-147) Line 1 Cursor Position
'RS = 0 :senddata = 192 : GOSUB Send : RS = 4        '(192-211) Line 2 Cursor Position
'RS = 0 :senddata = 148 : GOSUB Send : RS = 4	     '(148-167) Line 3 Cursor Position ~ continuation of line 1
'RS = 0 :senddata = 212 : GOSUB Send : RS = 4	     '(212-231) Line 4 Cursor Position ~ continuation of line 2
'RS = 0 :senddata =  13 : GOSUB Send : RS = 4             '(13) Blinking Cursor
'RS = 0 :senddata =  14 : GOSUB Send : RS = 4             '(14) Underline Cursor
'RS = 0 :senddata =  16 : GOSUB Send : RS = 4             '(16) Move Cursor Left
'RS = 0 :senddata =  20 : GOSUB Send : RS = 4             '(20) Move Cursor Right
'RS = 0 :senddata =  24 : GOSUB Send : RS = 4             '(24) Shift Display Left
'RS = 0 :senddata =  28 : GOSUB Send : RS = 4             '(28) Shift Display Right
	#picaxe 20X2
	#no_data
	#terminal off
'            DB7     = B.7
'            DB6     = B.6
'            DB5     = B.5
'            DB4     = B.4
	SYMBOL E       = B.3
'            RS      = B.2
	SYMBOL senddata = W3  :  SYMBOL senddataMSB  = b7  : SYMBOL senddataLSB  = b6
	SYMBOL index    = b8
	SYMBOL RS       = b9
	SYMBOL minutes  = w8
	SYMBOL seconds  = w9
	SYMBOL looptime = w10
	TABLE	  0, ($30,$30,$30,$20,$20,$80,$0,$C0,$0,$10)  '(4Bit)(Function 8bit/2line/5x8)(Display On)(Clear Display)
	TABLE  40, ("marks  ")
 	dirsB = %11111111
 	dirsC = %10111111
IntialiseLCD:
      FOR  index = 0 to 9
 READTABLE index, senddata : outpinsB = senddata : PULSOUT E,1 ' Initialise LCD
 	NEXT index  :  PAUSE 10
SETTIMER 62411
TIMER = 0
Main:
minutes = timer/600
LCDdisplay:
      FOR index = 40 TO 46
 	  READTABLE index, senddata : GOSUB Send ' sending characters to line one
 	NEXT index
 	FOR  index = 0 TO 6
 	NEXT index
 	  READTABLE index, senddata : GOSUB Send ' sending characters to line two
 	NEXT index
NEXT looptime : end                            ' Display time of 100 loops of program (15.3seconds)
   Send:  senddata = senddata <<4                    ' > send 4Bit Mode to LCD
	 outpinsB = senddataMsb <<4 | RS : PULSOUT E,1 ' \ valid data falling edge
	 outpinsB = senddataLsb | RS     : PULSOUT E,1 ' \ valid data falling edge
	                              RETURN
You might even find that not getting overly clever with nibble manipulation is faster ...
Send: outpinsB = senddata & $F0 | RS : PULSOUT E,1
      outpinsB = senddata << 4  | RS : PULSOUT E,1
      RETURN
If you can put the RS pin on a different port you can improve speed even more by losing both "|RS" and, if you've done that, then you can go to 8-bit output.
While RS should be stable before E pulses you may be able to diode mix ( maybe using an RC ) so you can use 4-bit and pulse one of two pins so you get an E with RS and an E without RS which can be on the same port and still lose the "|RS".
Make your own 8 bit board
Thanks for that Hippy!
I guess I over nibbled
too many refreshments too lol.
Using your code gives a 3% improvement again.
Selection of those pinouts were because they seem to be in common use
and was just after a rough comparison.
When using RS on a different port we get another 5% improvement
so the gap is narrowing 8 Bit is now only 28% faster than 4 Bit.
I must amit i,ve only used the AND OR statements for single bits
now yourve pointed that out it does look obvious now!
well when you write it out it does lol and reread manual 2.
Senddata  0101 0101
AND $F0   1111 0000
      =   0101 0000
OR RS     0000 0100
      =   0101 0100
Ive just finished making an 8 Bit board for those interested in making your own ax133copy
now someone whats a clock for Chrissy! so I guess i'll look at a 4 Bit version
using the 18m2 which i'm liking more & more. with i2c and the ds3231.
I guess i'll look at a 4 Bit version using the 18m2 which i'm liking more & more. with i2c and the ds3231.
Note that using I2C pins will mess up existing data bit to physical pin mapping which means more complicated bit-twiddling or reallocating pins. On the 18M2 when using I2C you can't put the 4-bit LCD data nibble on B.0-B.3 nor B.4-B.7. Using C.0-C.3 could however work. Or you could do software bit-banged I2C.
Thanks hippy ! yes I'll be using c0 to c3
and hopefully reduce the code too
Send: outpinsB = senddata /16: PULSOUT E,1
untested lol
Make your own 4 bit board for the 18m2
Wow its almost Christmas!
hope its a good one for us all...
I just finished making a 4 Bit Board and thought it turned out quite good
we can also now make use of the hi2c pins too.
having both Boards we are now able to make some real comparisons with the 18m2.
Interestingly the 4bit board does really well being only 17% slower than the 8bit board.
here,s the test code for each.
	#picaxe 18m2
	#terminal off
'            DB7  = C.3
'            DB6  = C.2
'            DB5  = C.1
'            DB4  = C.0
'            SCK  = B.4
'            SDA  = B.1
	SYMBOL E    = B.6
	SYMBOL RS   = B.7
	SYMBOL index       = b1
	SYMBOL Refreshrate = b2
      SYMBOL D1          = b3
	SYMBOL D2          = b4
	SYMBOL D3          = b5
	SYMBOL D4          = b6
	SYMBOL D5          = b7
	EEPROM	  0,($03,$03,$03,$02,$02,$08,$0,$0C,$0,$01)  '(4Bit)(Function 4bit/2line/5x8)(Display On)(Clear Display)
	EEPROM 40, ("marks  ")
	EEPROM 16, ("PICAXE 18M2 LCD")
      SETFREQ M8
 	dirsB = %11101101
 	dirsC = %00001111
Intialise:
	FOR  index = 0 to 9
          READ index, senddata : pinsC = senddata :PULSOUT E,1 ' Initialise LCD
Main:
   ENABLETIME
   BINTOASCII Refreshrate,D3,D2,D1
LCDdisplay:
LOW RS  :senddata = 128 : GOSUB Send : HIGH RS '(128-147) Line 1 Cursor Position
 	  READ index, senddata : GOSUB Send ' sending characters to line one
 	NEXT index
      FOR  index = 0 TO 5
 	  LOOKUP index,("  ",D3,D2," ",D1),senddata
 	NEXT index
LOW RS  :senddata = 192 : GOSUB Send : HIGH RS '(192-211) Line 2 Cursor Position
 	  READ index, senddata : GOSUB Send ' sending characters to line two
 	NEXT index
 	 INC Refreshrate
 	 IF time = 10 THEN Finish
     GOTO main
Send:  pinsC = senddata / 16 : PULSOUT E,1 :  pinsC = senddata : PULSOUT E,1 ' 4Bitmode to LCD (14.2per second)
                            RETURN
Finish:END
'         COMMAND SUMMARY 8 BIT MODE
	#picaxe 18m2
	#terminal off
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
'            DB3  = B.3
'            DB2  = B.2
'            DB1  = B.1
'            DB0  = B.0
	SYMBOL E    = C.6
	SYMBOL RS   = C.7
	SYMBOL index       = b1
      SYMBOL D1          = b3
	SYMBOL D2          = b4
	SYMBOL D3          = b5
	SYMBOL D4          = b6
	SYMBOL D5          = b7
	EEPROM	  0,($38,$38,$38,$0C,$01) '(Function 8bit/2line/5x8)(Display On)(Clear Display)
      SETFREQ M8
 	dirsB = %11111111
 	dirsC = %11001111
Intialise:
	FOR  index = 0 to 4
          READ index, senddata : pinsB = senddata :PULSOUT E,1 ' Initialise LCD
Main:
   ENABLETIME
LCDdisplay:
 	NEXT index
      FOR  index = 0 TO 5
 	NEXT index
 	NEXT index
 	 INC Refreshrate
     GOTO main
Send:  pinsB = senddata : PULSOUT E,1 ' 8Bitmode to LCD (16.6per second)
                            RETURN
Finish:END
4 BIT 8 BIT LCD Serial driver
Wow this code snipet has turned into a full blown project lol.Got myself another 18m2 unfortunately there both an early version 2.A
Hopefully when the BLUE OLED becomes available on TECHSUPPLIES I may get the latest version withit lol.
The LCD driver for both boards is almost identical.
When we power up the supply voltage is read form the internal adc which is very accurate.and will display (LCD Supply 5.0v)
We also load our Custom Characters just edit the eeprom statements for whats required.
You can uncomment statements to test and display your characters.
The display may operate a little diffferently but you still should be able to use the same standard commands.
We also have a control section to do our stuff ! lol
an example if we what output 1 high we send (254,$21) and to make output 1 low (254,$20)
Both 4bit and 8bit boards run at 4800 bps and 32mhz they seem quick
so really the 4 bit board has the advantage and makes native Hi2c available.
#picaxe 18m2  ' version 2.A * Testdrive 4bit/8bit Serial driver boards* marks
SETFREQ M16
serout c.0,n4800_16,(254,192)   ' Command Line 2 Cursor Position
serout c.0,n4800_16,("can't wait Santa")
  serout c.0,n4800_16,(254,$21) ' Control High OUTPUT 1
pause 1200
serout c.0,n4800_16,("                ")
  serout c.0,n4800_16,(254,$20) ' Control Low OUTPUT 1
pause 1200
	#picaxe 18m2    'version 2.A * 8 BIT SERIAL DRIVER 4800 baud * marks
	#terminal off
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
'            DB3  = B.3
'            DB2  = B.2
'            DB1  = B.1
'            DB0  = B.0
      SYMBOL Rx   = C.5
	SYMBOL E    = C.6
	SYMBOL RS   = C.7
	SYMBOL senddata    = b0	 SYMBOL sentdata    = b0
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
      EEPROM 0 ,($38,$38,$38,$0C,$01)    '(Function 8bit/2line/5x8)(Display On)(Clear Display)	 16  8  4  2  1
      EEPROM 10,(6 ,9 ,9 ,6 ,0 ,0 ,0 ,0) ' load custom character (o) =0                           *  '  '  '  *  17
      EEPROM 18,(14,17,17,31,17,17,0 ,0) ' load custom character (A) =1                           *  *  '  *  *  27
      EEPROM 26,(30,17,17,30,16,16,0 ,0) ' load custom character (P) =2                           *  '  *  '  *  21
      EEPROM 34,(17,27,21,17,17,17,0 ,0) ' load custom character (M) =3                           *  '  '  '  *  17
      EEPROM 42,(14,17,16,16,17,14,0 ,0) ' load custom character (C) =4                           *  '  '  '  *  17
      EEPROM 50,(30,16,16,28,16,16,0 ,0) ' load custom character (F) =5                           *  '  '  '  *  17
      EEPROM 58,(0 ,31,1 ,31,16,16,31,0) ' load custom character (2) =6                           '  '  '  '  '  0
      EEPROM 66,(14,10,14,0 ,14,10,10,0) ' load custom character (on)=7                           '  '  '  '  '  0
                                         '                                                     custom character example (M)=3
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
 	batV = 10475 / ADCval
      BinToAscii batV,D2,D2,D1
Initialise:
	FOR  index = 0 to 4
          READ index, senddata : pinsB = senddata : PULSOUT E,1 ' Initialise LCD
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
 	    LOOKUP index,("LCD Supply ",D2,".",D1,"V "),sentdata
 	                           pinsB = senddata : PULSOUT E,1 ' sending characters to line one
      NEXT index
LoadCustomCharactersFromEEPROM:
       LOW RS : senddata = $40 : pinsB = senddata : PULSOUT E,1 : HIGH RS ' Load Characters to LCD
 	FOR  index =10 TO 73
 	    READ index, senddata : pinsB = senddata : PULSOUT E,1 ' sending characters to LCD
 	NEXT index
' TestCustomCharacters:
'       LOW RS  :senddata = 192 : pinsB = senddata : PULSOUT E,1 '(192-211) Line 2 Cursor Position
' HIGH RS
'      FOR  index = 0 TO 12
' 	    LOOKUP index,("Test ",0,1,2,3,4,5,6,7),sentdata
' 	                            pinsB = senddata : PULSOUT E,1 ' sending characters to line two
'      NEXT index
Main:
   SERIN Rx,N4800_32,sentdata
   IF sentdata = 254 THEN Commands
   pinsB = sentdata : PULSOUT E,1
   GOTO Main
Commands:
   pinsB = sentdata
   index = sentdata / 16: IF index = $2 then Control
   LOW RS
    PULSOUT E,1
   HIGH RS
    GOTO Main
Control:
   SELECT CASE sentdata
   case  $20  low c.0
   case  $21 high c.0
   case  $22  low c.1
   case  $23 high c.1
   case  $24  low c.2
   case  $25 high c.2
   END SELECT
    GOTO Main
	#picaxe 18m2    'version 2.A * 4 BIT SERIAL DRIVER 4800 baud * marks
	#terminal off
'            DB7  = C.3
'            DB6  = C.2
'            DB5  = C.1
'            DB4  = C.0
      SYMBOL Rx   = C.5
	SYMBOL E    = B.6
	SYMBOL RS   = B.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
      EEPROM 0 ,($03,$03,$03,$02,$02,$08,$0,$0C,$0,$01)'(4Bit)(2line/5x8)(Display On)(Clear Display)   16  8  4  2  1
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11101101
 	dirsC = %00001111
Initialise:
	FOR  index = 0 to 9
          READ index, senddata : pinsC = senddata : PULSOUT E,1 ' Initialise LCD
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
 	                           pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 ' sending characters to line one
      NEXT index
       LOW RS : senddata = $40 : pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 : HIGH RS ' Load Characters to LCD
 	FOR  index =10 TO 73
 	    READ index, senddata : pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 ' sending characters to LCD
 	NEXT index
'       LOW RS  :senddata = 192 : pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1  '(192-211) Line 2 Cursor Position
'      HIGH RS
' 	                            pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 ' sending characters to line two
'      NEXT index
Main:
   GOTO Main
Commands:
   IF pinsc = $2 then Control
   LOW RS
   HIGH RS
    GOTO Main
Control:
   case  $20  low b.0
   case  $21 high b.0
   case  $22  low b.5
   case  $23 high b.5
   case  $24  low b.2
   case  $25 high b.2
   case  $26  low b.3
   case  $27 high b.3
   END SELECT
    GOTO Main
4 BIT 8 BIT LCD SERIAL DRIVER @ 9600bps 18m2
While 4800 baud is good we dont need to use any pauses!
9600 baud is quite popular as an Industry standard.
If we want our 18m2 to go faster we need to send a PAUSE 2 between bytes so it can keep up,
this does make our code a bit messy lol! and not very practical.
Another alternative could be using the byte-scratchpad pointer.
as i'm using a 1602 LCD this example is limited to sending upto 16 characters together
and proberly all thats needed for larger LCD's anyway thats easily changed.
here's the code for our 4 bit and 8bit Boards every time we serial out we should use a PAUSE 2.
They also make handy project boards lol!
SETFREQ M16
                                ' when using 4bit board to send I use c.0
serout b.0,n9600_16,(254,192)   ' Command Line 2 Cursor Position
pause 2
serout b.0,n9600_16,("Marks 9600 bps")
  serout b.0,n9600_16,(254,$21) ' Control High OUTPUT 1
pause 4000
pause 2
serout b.0,n9600_16,("                ")
  serout b.0,n9600_16,(254,$20) ' Control Low OUTPUT 1
pause 2000
	#picaxe 18m2    'version 2.A * 8 BIT SERIAL DRIVER 9600 baud * marks
	#terminal off
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
'            DB3  = B.3
'            DB2  = B.2
'            DB1  = B.1
'            DB0  = B.0
      SYMBOL Rx   = C.5
	SYMBOL E    = C.6
	SYMBOL RS   = C.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
Initialise:
	FOR  index = 0 to 4
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
 	    LOOKUP index,("LCD Supply ",D2,".",D1,"V "),senddata
      NEXT index
 	FOR  index =10 TO 73
 	NEXT index
' HIGH RS
' 	    LOOKUP index,("Test ",0,1,2,3,4,5,6,7),senddata
'      NEXT index
Main:
     bptr=28
   SERIN Rx,N9600_32,@bptr
   IF @bptrinc = 254 THEN Commands
   SERIN [10],Rx,N9600_32,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc
    @bptr = 254
     bptr = 28
       do until @bptr = 254
         pinsB = @bptrinc : PULSOUT E,1
   GOTO Main
Commands:
   SERIN Rx,N9600_32,sentdata
   pinsB = sentdata
   LOW RS
    PULSOUT E,1
   HIGH RS
    GOTO Main
Control:
   case  $20  low c.0
   case  $21 high c.0
   case  $22  low c.1
   case  $23 high c.1
   case  $24  low c.2
   case  $25 high c.2
   END SELECT
    GOTO Main
	#picaxe 18m2    'version 2.A * 4 BIT SERIAL DRIVER 9600 baud * marks
	#terminal off
'            DB7  = C.3
'            DB6  = C.2
'            DB5  = C.1
'            DB4  = C.0
      SYMBOL Rx   = C.5
	SYMBOL E    = B.6
	SYMBOL RS   = B.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11101101
 	dirsC = %00001111
Initialise:
	FOR  index = 0 to 9
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
      NEXT index
 	FOR  index =10 TO 73
 	NEXT index
'      HIGH RS
'      NEXT index
Main:
    bptr=28
    @bptr = 254
     bptr = 28
        pinsC = @bptr / 16 : PULSOUT E,1 : pinsC = @bptrinc : PULSOUT E,1
   GOTO Main
Commands:
   pinsC = sentdata / 16
   LOW RS
    PULSOUT E,1 : pinsC = sentdata : PULSOUT E,1
   HIGH RS
    GOTO Main
Control:
   case  $20  low b.0
   case  $21 high b.0
   case  $22  low b.5
   case  $23 high b.5
   case  $24  low b.2
   case  $25 high b.2
   case  $26  low b.3
   case  $27 high b.3
   END SELECT
    GOTO Main
4 BIT OLED/LCD DRIVER FOR THE 20x2 using 9600Bps or Hi2C fast/slow
9600 Bps works really well on 20x2 driving a 4Bit OLED/LCD (B.0,B.1,B.2,B.3)
without using background receive
and our sending picaxe doesnt need any pauses
unlike the 18m2 driver that required a pause 4 at 32mhz from our sending picaxe.
We can also use Hi2C fast or slow to drive an OLED/LCD just use the same codes
we do need a few pauses tho example in the testdrive code.
i dont think we need another drawing every ones had enuff
2k pullups recommended for Hi2c and
for serial a 10k pulldown should be used.
default is usually 9600 mode if we want Hi2C power off
and power on both boards together so it can catch the interupt before it gets into 9600 serial mode.
#picaxe 18m2  ' version 2.A * Testdrive  4bit/20x2 Serial driver * marks
SETFREQ M32
serout c.0,n9600_32,(254,192)   ' Command Line 2 Cursor Position
serout c.0,n9600_32,("* *   9600 bps..")
serout c.0,n9600_32,(254,$21) ' Control A0 high
pause 4000
serout c.0,n9600_32,(" * *  9600 bps..")
serout c.0,n9600_32,(254,$20) ' Control A0 low
pause 4000
picaxe 18m2  ' version 2.A * Testdrive  4bit/20x2 Hi2C driver * marks
SETFREQ M32
HI2CSETUP I2CMASTER,%10100000,I2Cfast_32,I2Cbyte
pause 4000
HI2COUT 0,(254,192) ' Command Line 2 Cursor Position
pause 10
HI2COUT 0,("*    Hi2C ABCDEF")
pause 40
HI2COUT 0,(254,$21) ' Control A0 high
pause 4000 '15 minimum
HI2COUT 0,(254,192)
pause 10
HI2COUT 0,(" *   Hi2C ABCDEF")
pause 40
HI2COUT 0,(254,$20) ' Control A0 low
pause 10
pause 40
HI2COUT 0,(254,192)
pause 10
pause 40
	#picaxe 20X2 ' version C.0 * 20x2 LCD/OLED driver 4Bit (9600Bps or Hi2C fast/slow )* marks
	#no_data
	#terminal off
'            SCK	   = B.7
'            SDA     = B.5
'            DB7     = B.3
'            DB6     = B.2
'            DB5     = B.1
'            DB4     = B.0
	SYMBOL E       = c.3
      SYMBOL RS      = c.2
     	SYMBOL Rx      = c.7
	SYMBOL senddata = b0 : SYMBOL sentdata = b0
	SYMBOL index    = b1
	TABLE   0, ($3,$3,$3,$2,$2,$8,$0,$C,$0,$1,$0,$2,$0,$6)  '(4Bit)(2line/5x8)(Display On)(Clear Display)(Return Home)(Entry Mode Set)
	TABLE  40, ("marks......")
	SETFREQ M64
	HI2CSETUP I2CSLAVE, %10100000
 	dirsB = %00001111
 	dirsC = %10111111
 	SETINTFLAGS %01000000 , %01000000
IntialiseDisplay:
      FOR  index = 0 to 13
READTABLE index, senddata : outpinsB = senddata : PULSOUT E,1 ' Initialise LCD/OLED
Display:
      LOW RS
      senddata = 128 : outpinsB = senddata >> 4 : PULSOUT E,1 : outpinsB = senddata : PULSOUT E,1'(128-147) Line 1 Cursor Position
      HIGH RS
      FOR index = 40 TO 50
 	   outpinsB = senddata >> 4 : PULSOUT E,1 : outpinsB = senddata : PULSOUT E,1 ' sending characters to line one
 	   pause 500
 	NEXT index
 Main:
  SERIN Rx,N9600_64,sentdata
   outpinsB = sentdata >> 4 : PULSOUT E,1 : outpinsB = sentdata : PULSOUT E,1
   GOTO main
 Commands:
    IF outpinsB = $2 then Control
    LOW RS : PULSOUT E,1 : outpinsB = sentdata : PULSOUT E,1 : HIGH RS
    GOTO Main
 Control:
    case  $20  low a.0
    case  $21 high a.0
    END SELECT
    GOTO Main
  Hi2C:
  ptr = 0
  hi2cflag = 0
  HI2CSETUP I2CSLAVE , %10100000
Interrupt:
PAUSE 1000
 ptr = 0
 IF @ptrinc = 254 THEN CommandsHi2c
 FOR  ptr = 0 TO hi2clast
 outpinsB = @ptr >> 4  PULSOUT E,1 : outpinsB = @ptr  PULSOUT E,1
 NEXT ptr
 GOTO Hi2C
 CommandsHi2c:
 IF outpinsB = $2 THEN ControlHi2c
 LOW RS : PULSOUT E,1 : outpinsB = @ptr : PULSOUT E,1 : HIGH RS
 GOTO Hi2C
 ControlHi2c:
    SELECT CASE @ptr
    case  $20  low a.0
    case  $21 high a.0
    END SELECT
    GOTO Hi2C
Use your supplied 8 BIT Serial Board with your OLED at 4800 Bps
This is turning into a bit of a blog hope nobody minds lol!
Well I just couldn't wait for a blue one ending up with a 20x4 OLED
yellow on black from techsupplies.(Fast n Easy I think i'll being going direct from now on)
(was happy to get version 2.D on my 18m2)
On the supplied serial driver does not use the standard pinouts for lcd's with backlight being 15 and 16
A tantulam capacitor can be easily added for smoother supply if using the adc's where the contrast pot would usually go.
Not much time to roadtest this weekend >
The brightness was not a problem like some report'
nice and clear and can be seen from some distance.
The specs are 30ma @ 5v with a brightness level of 125 nits
with a minimum of 3v and 80 nits hardly noticing any drop in brightness
although it still works down to about 2v.
So for displays that are always on those wanting longer life i guess 3v is best.
I did have too change the code slightly it behaves just like an lcd should.
So for those wanting to try 4800 bps with there OLED some example code follows!
Really its what should be used for an lcd so this code can be used for both without change.
After reprogramming the code resets the OLED so no need to power off and on !
Default character font is EnglishJapanese which everyone seems to be most familiar with.
Well verdict I guess everyone should have at least 1 lol!
I do wonder how it compares to one of those RGB on Black LCD's (good if they supplied these too lol)
SETFREQ M32
serout c.0,n4800_32,(254,192)   ' Command Line 2 Cursor Position
serout c.0,n4800_32,("can't wait for a")
  serout c.0,n4800_32,(254,$21) ' Control High OUTPUT 1
pause 5000
serout c.0,n4800_32,("blue Oled  Santa")
  serout c.0,n4800_32,(254,$20) ' Control Low OUTPUT 1
pause 5000
	#picaxe 18m2    'version 2.D * 8 BIT SERIAL DRIVER OLED FRIENDLY 4800 baud * marks
	#terminal off
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
'            DB3  = B.3
'            DB2  = B.2
'            DB1  = B.1
'            DB0  = B.0
      SYMBOL Rx   = C.5
	SYMBOL E    = C.6
	SYMBOL RS   = C.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
	EEPROM 5 ,($2,$6)                    '(Return Home)(Entry Mode Set)
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
Initialise:
	FOR  index = 0 to 6
          READ index, senddata : pinsB = senddata : PULSOUT E,1           ' Initialise OLED
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
 	    LOOKUP index,("OLED Supply ",D2,".",D1,"V"),senddata
      NEXT index
       LOW RS : senddata = $40 : pinsB = senddata : PULSOUT E,1 : HIGH RS ' Load Custom Characters into OLED
 	FOR  index =10 TO 73
 	    READ index, senddata : pinsB = senddata : PULSOUT E,1           ' sending characters to OLED
 	NEXT index
           HIGH RS
           FOR  index = 0 TO 13
 	          LOOKUP index,("Test ",0,1,2,3,4,5,6,7,223),senddata
           NEXT index
Main:
   GOTO Main
Commands:
   pinsB = sentdata
   LOW RS
    PULSOUT E,1
   HIGH RS
    GOTO Main
Control:
   case  $20  low c.0
   case  $21 high c.0
   case  $22  low c.1
   case  $23 high c.1
   case  $24  low c.2
   case  $25 high c.2
   END SELECT
    GOTO Main
Marks.
I have your lcd code running on a 20x2 and just can't puzzle out how to get a variable to display on the lcd, I'm trying to do a readtemp as the tester, whats the trick to it?
I can get stuff pre-saved to tables onto it but making my head hurt with the variable direct.
Hi Captain Haddock,
your not alone my head hurts too sometimes LOL!
the easiest way I,ve found is using the BINTOASCII and LOOKUP commands.
here's an example...
	#picaxe 18m2    'version 2.A  * 8 BIT SERIAL DRIVER OLED/LCD FRIENDLY * marks
	#terminal off   'version 2.D  * tested O.K. also *
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
'            DB3  = B.3
'            DB2  = B.2
'            DB1  = B.1
'            DB0  = B.0
	SYMBOL Ds18b20 = C.0
      SYMBOL Rx      = C.5
	SYMBOL E       = C.6
	SYMBOL RS      = C.7
	SYMBOL index       = b1
	SYMBOL ADCval      = b2
	SYMBOL SupplyV     = b3
	SYMBOL Temperature = W2  SYMBOL TempMsb  = b5  SYMBOL TempLsb = b4
	SYMBOL Sign        = b6
	SYMBOL D0          = b7
      SYMBOL D1          = b8
	SYMBOL D2          = b9
	SYMBOL D3          = b10
	SYMBOL D4          = b11
	EEPROM 0 ,($38,$38,$38,$C,$1,$2,$6)'(Function 8bit/2line/5x8)(Display On)(Clear Display)(Return Home)(Entry Mode Set)   	                                   '
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
 	SupplyV = 10475 / ADCval
      BinToAscii SupplyV,D2,D2,D1
Initialise:
	FOR  index = 0 to 6
          READ index, senddata : pinsB = senddata : PULSOUT E,1 ' Initialise OLED/LCD
DisplaySupplyAtPowerUp:
	HIGH RS                                                   ' charactermode
      FOR  index = 0 TO 14
 	    LOOKUP index,("   Supply ",D2,".",D1," V"),senddata
      NEXT index : PAUSE 8000
ClearDisplay:
      LOW RS  :senddata = 1 : pinsB = senddata : PULSOUT E,1 : HIGH RS ' ClearDisplay
Main:
Readtemp12 Ds18b20,Temperature
  Convert:
       Sign = " "                                               '  Display +
     IF TempMsb > 127 THEN
       Sign = "-"                                               '  Display -
     Temperature = - Temperature
     ENDIF
     Temperature = Temperature * 25 / 4 + 5                     '  Celsius + rounding up 0.05 to 0.09 (0.1)resolutuion
     BINTOASCII Temperature,D4,D3,D2,D1,D0
      IF  D4 = "0" THEN : D4 = " "                              ' zero blanking
       IF D3 = "0" THEN : D3 = " " : ENDIF                      ' zero blanking
      ENDIF
   Display:
   LOW RS  :senddata = 192 : pinsB = senddata : PULSOUT E,1 : HIGH RS '(192-211) Line 2 Cursor Position
   FOR  index = 0 TO 15
    	    LOOKUP index,("  ",Sign, D4,D3,D2,".",D1,223,"Celsius"),senddata
   NEXT index
GOTO Main
Thanks Marks
At my level of axeing I'll probably stick to serial drivers for the projects on the go but I am going to keep playing with this as I love the idea of driving the display directly, I was chuffed just to see the 'marks-picaxe 20x2 ldc' come up:D
Thanks for all the hard work put in.
bintoascii,poke,and lookup seems to do the trick, I was originally assuming there was a way to just send the output in a similar way to the serout command with the serial driver.
I'll get there!
Many thanks again for the original code.
Edit:
Don't know why I thought I had to use the poke command, Doh!
After having more of a play it is surprisingly easy to use realy, is there a 20x2 version of the 4 bit code? I tried the convert wizard with the 18m2 version but with no luck, it'd be nice to free up a few pins, especially the hi2c pins.
Hi Captain Haddock,
yes I can see there would be a problem with that conversion.
Post #20 already has (20x2 4bit for oled/lcd).
main: program which is the serial and hi2c driver
based on this drawing now provided
and heres some code too hope it helps ....
Unfortunately I may have confused many with the use of the 20x2 and 18m2 mixed in this thread
hopefully if it is read from start to finish it will be a bit more clearer for the end user.
	#picaxe 20X2 ' version C.0 * 20x2 4Bit LCD/OLED * marks
	#no_data
	#terminal off
'            SCK	   = B.7
'            SDA     = B.5
'            DB7     = B.3
'            DB6     = B.2
'            DB5     = B.1
'            DB4     = B.0
	SYMBOL E       = C.3
	SYMBOL RS      = C.2
     	SYMBOL Rx      = C.7
	SYMBOL index    = b1
	SYMBOL ADCval      = b2
	SYMBOL SupplyV     = b3
	SYMBOL Sign        = b6
	SYMBOL D0          = b7
	SYMBOL D1          = b8
	SYMBOL D2          = b9
	SYMBOL D3          = b10
	SYMBOL D4          = b11
	CALIBADC10 ADCval
	SETFREQ M64
 	dirsB = %00001111
 	dirsC = %10111111
IntialiseDisplay:
      FOR  index = 0 to 13
DisplayMarks:
 	  pause 500
 	NEXT index
        outpinsB = senddata >> 4 : PULSOUT E,1 : outpinsB = senddata : PULSOUT E,1 : HIGH RS '(192-211) Line 2 Cursor Position
      FOR  index = 0 TO 14
      NEXT index : PAUSE 10000
 Main:
  Convert:
'    Temperature = Temperature  + 880 * 9 / 5 - 1072                 ' *uncomment for Fahrenheit (-67.0 to 257.0)
'    Temperature =  Temperature + 4370                               ' *uncomment for Kelvin     (218.1 to 398.1)
     ENDIF
    Temperature = Temperature  * 5 / 4 * 5 + 5                      '  Celsius (-55.0 to 125.0) rounding up 0.05 to 0.09
      IF  D4 = "0" THEN : D4 = " "                                  ' leading zero blanking
       IF D3 = "0" THEN : D3 = " " : ENDIF                          ' leading zero blanking
      ENDIF
  DisplayTemperature:
    FOR  index = 0 TO 15
    NEXT index
GOTO Main
Thanks again Marks, working in 20 seconds from pulling 8 bit circuit apart!
I think I may have got lost somewhere back in the thread, I've been through it a few times but always been in a rush due to looking at work.
been trying this on a 40x2 port D on a breadboard.(to suit pre-made board in a control box I have)
Is there any reason why I can't get pins 4-7 of a port to work in 4 bit mode? I've changed dirsD to %11110000/%00001111/%11111111 and can't seem to get anything happening, I've tried port B using pins 0-3 with no problems as well as 0-7 in 8 bit mode and that worked ok.
How do you get the pulseout to just work with the 4 top pins of the port?
I've edited this to take out all the bits I've found answers to as it was getting too confusing.
Hi Captain Haddock,
No no reason ,I think you'll need to swap these lines as well
TABLE 0, ($30,$30,$30,$20,$20,$80,$0,$C0,$0,$10,$0,$20,$0,$60) '(4Bit)(2line/5x8)(Display On)(Clear Display)(Return Home)(Entry Mode Set)for pins 4 5 6 7
IntialiseDisplay: 'code stays the same
Send: ' statements become
outpinsB = senddata : PULSOUT E,1 : outpinsB = senddata << 4 : PULSOUT E,1 for pins 4 5 6 7
not tested just cut from the 20x2 code above , hopefully should work lol.
Thanks Marks I'll try that, I think I just got it stuck in my head that the pulseout was only working from the bottom of the port upwards, no idea why but once you get an idea it tends to stick, it's all good learning.
ARRGGH!
It's just not happening for me, I can't seem to get it working using db4-7 on outpinsD 4-7 with E on A.2 and RS on A.4 whatever I do.
Edit: I think I finally understand how it all works thanks to a reply by Hippy on the active picaxe forum, I now have a very simple program running on a 20x2 with 4bit pins spread all over the place just to see if it works.
Now back to the 40x2....
Thanks to all for all the help on this subject!:)
I also have a sneaking suspicion I have been getting stitched up by a dodgy jumper wire on my breadboard giving bad results and a lot of confusion :mad:
This is the code I now have working which may help others getting confused by working with nibbles:
       #picaxe 20X2
       #no_data
       #terminal off
       SYMBOL E       = C.2
       SYMBOL RS      = C.1
       SYMBOL index    = b1
       dirsB = %11111111
       dirsC = %10111111
Init:
      FOR  index = 0 to 13
      LOOKUP index,($38,$38,$38,$2,$2,$8,$0,$C,$0,$1,$0,$2,$0,$6),senddata
      outpinB.4 = bit0 : outpinC.5 = bit1 : outpinB.6 = bit2 : outpinB.1 = bit3
      PULSOUT E,1
Main:
      senddata = 128 : gosub command
      FOR  index = 0 TO 9
      LOOKUP index,("    Hello!"),senddata : gosub display
      NEXT index
      senddata = 192 : gosub command
      FOR  index = 0 TO 9
      LOOKUP index,("    World!"),senddata : gosub display
      NEXT index
      PAUSE 1000
      senddata = 1 : gosub command
      GOTO Main
display:
	outpinB.4 = bit4 : outpinC.5 = bit5 : outpinB.6 = bit6 : outpinB.1 = bit7
	PULSOUT E,1
	PULSOUT E,1
command:
	LOW RS
      PULSOUT E,1
Hi Captain Haddock,
ARRGGH! noticed you were having fun lol!
got myself a 40x2 today to tryout "ouch" no lunch for 3 days.
and all those pins confused me too dont know what to do with em.
heres an example for you to try using D port D.4,D.5,D.6,D.7
and A.2 enable / A.3 RS
	#picaxe 40X2 ' version B.3 * 4Bit OLED/LCD * marks
	#no_data
	#terminal off
'            DB7     = D.7
'            DB6     = D.6
'            DB5     = D.5
'            DB4     = D.4
	SYMBOL E       = a.2
	SYMBOL RS      = a.3
	SYMBOL index    = b1
	SYMBOL ADCval      = b2
	SYMBOL SupplyV     = b3
	SYMBOL Sign        = b6
	SYMBOL D0          = b7
	SYMBOL D1          = b8
	SYMBOL D2          = b9
	SYMBOL D3          = b10
	SYMBOL D4          = b11
	TABLE   0, ($30,$30,$30,$20,$20,$80,$0,$C0,$0,$10,$0,$20,$0,$60)  '(4Bit)pins4567(2line/5x8)(Display On)(Clear Display)(Return Home)(Entry Mode Set)
	TABLE  40, ("CaptainHaddock..")
	CALIBADC10 ADCval
	SETFREQ M16
 	dirsD = %11110000
 	dirsA = %11111111
IntialiseDisplay:
      FOR  index = 0 to 13
READTABLE index, senddata : outpinsD = senddata : PAUSE 2 : PULSOUT E,1 ' Initialise OLED/LCD
DisplayMarks:
      FOR index = 40 TO 55
 	  outpinsD = senddata  : PULSOUT E,1 : outpinsD = senddata << 4: PULSOUT E,1 ' sending characters to line one
 	  pause 800
 	NEXT index
        outpinsD = senddata  : PULSOUT E,1 : outpinsD = senddata << 4: PULSOUT E,1 : HIGH RS '(192-211) Line 2 Cursor Position
      FOR  index = 0 TO 14
      NEXT index : PAUSE 4000
Clearline:
        outpinsD = senddata  : PULSOUT E,1 : outpinsD = senddata << 4: PULSOUT E,1 : HIGH RS '(128-147) Line 1 Cursor Position
      FOR  index = 0 TO 15
 	  Let senddata =" "
 	  pause 200
      NEXT index
 Main:
  Convert:
     ENDIF
      ENDIF
  DisplayTemperature:
    FOR  index = 0 TO 15
    NEXT index
GOTO Main
Problems with transmission to LCD
Following this thread, I tried to play around with an equivalent LCD, but have run into the following problem.
In the following program fragments I try to change to a lower frequency in the LCD program. I've tried to change the transmission speed accordingly so that when I change to M16 I also change the transmission to N4800_16. What I'd like to achieve is to run the program in "standard" rate. But the transmission only works when the numbers are unchanged, as shown.
LCD prg.:
	#picaxe 18m2
	#terminal off
	SYMBOL Rx   = C.5
	SYMBOL E    = C.6
	SYMBOL RS   = C.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
     SYMBOL D1          = b4
	SYMBOL D2          = b5
	SYMBOL baud = N4800_32
	SETFREQ M32
	EEPROM 10,($00,$00,$1A,$05,$0F,$14,$0F,$00);æ=0
	EEPROM 18,($00,$00,$01,$0E,$15,$15,$0E,$10);ø=1
	EEPROM 26,($04,$00,$0E,$01,$0F,$11,$0f,$00);å=2
	EEPROM 34,($07,$0C,$14,$17,$1C,$14,$17,$00);Æ=3
	EEPROM 42,($01,$0E,$13,$15,$19,$0E,$10,$00);Ø=4
	EEPROM 50,($04,$0A,$04,$0E,$11,$1F,$11,$00);Å=5
 	dirsB = %11111111
 	dirsC = %11001111
Initialise:
	FOR  index = 0 to 4
          pinsB = senddata
 	NEXT index
 	PAUSE 10
     LOW RS
     senddata = $40
     pinsB = senddata
     PULSOUT E,1
 	FOR  index =10 TO 73
 	    	pinsB = senddata
 	NEXT index
     LOW RS
     senddata = 192
     pinsB = senddata
 	HIGH RS
     FOR  index = 0 TO 12
 	    	pinsB = senddata
    	NEXT index
Main:
   	SERIN Rx,baud,senddata
   	IF senddata = 254 then Commands
   	pinsB = senddata
   	PULSOUT E,1
   	GOTO Main
Commands:
   	pinsB = senddata
   	index = senddata / 16
   	LOW RS
   	PULSOUT E,1
   	HIGH RS
   	GOTO Main
Control:
   	SELECT CASE senddata
   	case  $20 low c.0
   	case  $21 high c.0
   	case  $22 low c.1
   	case  $23 high c.1
   	case  $24 low c.2
   	case  $25 high c.2
   	END SELECT
    	GOTO Main
Transmission Prg.:
#PICAXE 08m2
#Terminal off
#No_Data
	SYMBOL baud = N4800_16
	SETFREQ M16
	pause 500
	if pin3 = 0 then main
	serout 1,baud, (254,1)
	pause 30
	serout 1,baud, (254,128)
	pause 10
	SerOut 1, baud, ("Hallo ",0,1,2,3,4,5);Shows "Hallo æøåÆØÅ"
	Do
		serout 1,baud, (254,192)
		serout 1,baud,(#w5)
		if w5 = 65535 then gosub clear1
		inc w5
		pause 500
	Loop
clear1:
	serout 1,baud,("     ")
Maybe I don't understand the relationship between Setfreq and Baudmode??
Any hints?
Hi wlie,
thanks for your interest
Your receiving 18m2 with the lcd program needs to run at 32mhz so it is fast enough
to process a serial stream at 4800 baud.
processor time is needed to update the display between each byte sent in a serial stream.
At 16mhz you'll proberly only achieve 2400 baud.
Thanks Marks
This cleared every things for me - it now works like I want it to do.
And also the part which translate the 6 special danish characters.
(Sorry if my English is difficult to understand - I read it better than I write it)
Initialising a LCD or OLED on the AXE132.
Its good to see there's been plenty of interest LCD's lately
As some are just after some simple code to get them started
here's some we can try on the AXE132 using 8Bit or 4Bit.
If our Display fails to initialise at Power up we can wake it up by sending (Wakeup) ($30,$30,$30)
Newer Displays will also reset by sending (Reset)($0,$0,$0,$0,$0)
8Bit command sequence.
($38,$38,$38) combined wakeup and function set 8Bit/2line
($0C) Display On / no cursor
($01) Clear Display
($02) Send Home
($06) Entry Mode
#picaxe 18m2  '  AXE132 8Bit marks
'           DB7  = B.7
'           DB6  = B.6
'           DB5  = B.5
'           DB4  = B.4
'           DB3  = B.3
'           DB2  = B.2
'           DB1  = B.1
'           DB0  = B.0
 SYMBOL Rx  = C.5
 SYMBOL  E  = C.6
 SYMBOL RS  = C.7
 SYMBOL senddata    = pinsb
 SYMBOL index       = b0
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
Initialise:
	FOR  index = 0 to 6
          LOOKUP index, ($38,$38,$38,$0F,$01,$02,$06),senddata : PULSOUT E,1 ' Initialise LCD/OLED
          '(8bit/2line/5x8)*3(Display On/flashing Cursor)(Clear Display)(Return Home)(Entry Mode Set)
      Display:
            LOW  RS                                     ' commandmode
            senddata = $01 : PULSOUT E,1  : PAUSE 12    ' Clear Display
            senddata = 132 : PULSOUT E,1                ' (128-147) Line 1 Cursor Position
           FOR  index = 0 TO 12
 	          LOOKUP index,("18M2 Picaxe!!"),senddata
           NEXT index
The same command sequence for 4Bit
$28 sets the Function to 4Bit/2line
after being set to 4Bit mode the command word is sent in two parts.
#picaxe 18m2  '  AXE132 4Bit marks
'            DB7  = B.7
'            DB6  = B.6
'            DB5  = B.5
'            DB4  = B.4
 SYMBOL Rx   = C.5
 SYMBOL E    = C.6
 SYMBOL RS   = C.7
 SYMBOL index     = b0
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
Initialise:
	FOR  index = 0 to 6
          LOOKUP index, ($33,$32,$28,$0C,$01,$02,$06),senddata : GOSUB Send    ' Initialise LCD/OLED
                       '(WakeUp)*3(Set4Bit)(4Bit/2Line)(DisplayOn)(Clear Display)(Return Home)(Entry Mode Set)
          Display:
            senddata = $01 :                                     GOSUB Send : PAUSE 10   ' Clear Display
            senddata = 192 :                                     GOSUB Send              ' (192-211) Line 2 Cursor Position
           FOR  index = 0 TO 12
 	        LOOKUP index,("Axe132 Picaxe"),senddata :        GOSUB Send              ' sending characters
           NEXT index
pause 500
goto display
       Send:
       PULSOUT E,1 : senddata = senddata*16 : PULSOUT E,1 :      RETURN
Picaxe18M2 (Count seconds INCremented by simple loop)
#picaxe 18m2  '  4Bit Using Alternative pins marks
 SYMBOL DB7  = outpinB.5
 SYMBOL DB6  = outpinB.4
 SYMBOL DB5  = outpinB.3
 SYMBOL DB4  = outpinB.2
 SYMBOL E    = B.1
 SYMBOL RS   = B.0
 SYMBOL index     = b1
      'value of count    = W1    ' b3,b2
      'display  count    = b4,b5,b6,b7,b8
      EEPROM 25,("Picaxe18M2")
      SETFREQ M32
 	dirsB = %11111111
 	dirsC = %11001111
Initialise:
	FOR  index = 0 to 6
      DisplayHello:
            senddata = 132 :                                     GOSUB Send              ' (128-147) Line 1 Cursor Position
            senddata = "H" :                                     GOSUB Send
            senddata = "e" :                                     GOSUB Send
            senddata = "l" :                                     GOSUB Send
            senddata = "o" :                                     GOSUB Send
pause 10000
           FOR  index = 25 to 34
 	     NEXT index
pause 4000
      Count1:
            senddata = 202 :                                     GOSUB Send              ' (192-211) Line 2 Cursor Position
      INC W1        ' add to W1
           BinToAscii W1,b8,b7,b6,b5,b4
           FOR  index = 0 TO 5                                                           ' sending characters
 	     LOOKUP index,(" ",b8,b7,b6,b5,b4),senddata :          GOSUB Send
           NEXT index
      PAUSE 8000        ' 1 second (M32)
goto count1
       Send:
         DB7 =   bit7
         DB6 =   bit6
         DB5 =   bit5
         DB4 =   bit4
        PULSOUT E,1
         DB7 =   bit3
         DB6 =   bit2
         DB5 =   bit1
         DB4 =   bit0
Picaxe18X (Counter INCremented by INPUT1)
#picaxe 18x  '  4Bit Using Alternative pins marks
#terminal off
 SYMBOL DB7  = outpin5
 SYMBOL DB6  = outpin4
 SYMBOL DB5  = outpin3
 SYMBOL DB4  = outpin2
 'reset pin leg4 for 18x 4.7k to V+
 SYMBOL E   = B.1
 SYMBOL RS  = B.0
 SYMBOL InputSensor = INPUT1
 SYMBOL index     = b1
 SYMBOL Counter   = W1  ' b3,b2
 '  display CounterValue  = b4,b5,b6,b7,b8
      EEPROM 25,("GO Speedy ")
      SETFREQ M8
 Initialise:
	FOR  index = 0 to 6
        DisplaySpeedy:
           READ index, senddata :                                GOSUB Send              'sending character
 	     NEXT index
      DisplayCount:
           BinToAscii Counter,b8,b7,b6,b5,b4
           NEXT index
         DO
        IF InputSensor = 1 then Count1                                                   ' INPUT PIN as per SYMBOL
         LOOP
      Count1:
        IF InputSensor = 1 then Count1 : PAUSE 100                                       ' debounce abit
      Counter = Counter +1
      IF Counter > 9999 THEN : Counter = 0 : ENDIF                                       ' reset to zero
      GOTO DisplayCount
       Send:
         DB7 =   bit7
         DB6 =   bit6
         DB5 =   bit5
         DB4 =   bit4
        PULSOUT E,1
         DB7 =   bit3
         DB6 =   bit2
         DB5 =   bit1
         DB4 =   bit0
See schematic for common 8Bit /4Bit Layouts.
When an LCD is first powered on without initialising . The first line will be filled with block characters, this is so contrast can easily be adjusted.
If nothing can be seen check contrast adjustment there should be about 0.6v between PIN1(GND) and PIN3(VO) of the LCD.
Your supply should also be around 4.7v to 5v PIN1(GND) and PIN2 (VDD) for adequate pixel brightness.
I'm using this code to drive a 20x4 display, but it looks like its setup for 16 character displays, I tried changing some of the code which i thought set it to 16 but didnt work
	#terminal off
'            DB7  = C.3
'            DB6  = C.2
'            DB5  = C.1
'            DB4  = C.0
      SYMBOL Rx   = C.5
	SYMBOL E    = B.6
	SYMBOL RS   = B.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11101101
 	dirsC = %00001111
Initialise:
	FOR  index = 0 to 9
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
      NEXT index
 	FOR  index =10 TO 73
 	NEXT index
'      HIGH RS
'      NEXT index
Main:
    bptr=28
    @bptr = 254
     bptr = 28
   GOTO Main
Commands:
   LOW RS
   HIGH RS
    GOTO Main
this is what i'm sending
[color=Navy]#picaxe [/color][color=Black]08m2[/color]
[color=Navy]#no_data[/color]
[color=Blue]setfreq m8[/color]
[color=Black]init:[/color]
[color=Blue]pause [/color][color=Navy]1000 [/color][color=Green]; wait for display to initialise[/color]
[color=Black]main:[/color]
[color=Blue]do
serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]1[/color][color=Blue])
pause [/color][color=Navy]2[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]128[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]pause [/color][color=Navy]2     [/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Red]""[/color][color=Blue]) [/color][color=Green]; output text[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]192[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Red]"88888888888888888885"[/color][color=Blue]) [/color][color=Green]; output text[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]148[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]212[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Red]"88888888888888888888"[/color][color=Blue]) [/color][color=Green]; output text
      [/color]
[color=Blue]pause [/color][color=Navy]1000[/color]
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]1[/color][color=Blue])
[color=Blue]serout [/color][color=Navy]0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Red]"33333333333333333333"[/color][color=Blue]) [/color][color=Green]; output text[/color]
      [/color][color=Blue]pause [/color][color=Navy]1000[/color]
[color=Blue]loop[/color]
but its cutting off at 16 characters.
what needs to be changed?
Hi ac21,
increase the number of @bptrinc to whats required.
	#terminal off
'            DB7  = C.3
'            DB6  = C.2
'            DB5  = C.1
'            DB4  = C.0
      SYMBOL Rx   = C.5
	SYMBOL E    = B.6
	SYMBOL RS   = B.7
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11101101
 	dirsC = %00001111
Initialise:
	FOR  index = 0 to 9
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
      NEXT index
 	FOR  index =10 TO 73
 	NEXT index
'      HIGH RS
'      NEXT index
Main:
    bptr=28
   SERIN [10],Rx,N9600_32,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,_
                          @bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc ' send upto 20 characters
    @bptr = 254
     bptr = 28
   GOTO Main
Commands:
   'IF pinsc = $2 then Control  '  to control outputs if used
   LOW RS
   HIGH RS
    GOTO Main
To send n9600 reliably , your picaxe needs to run at 16 mhz or more
#picaxe 08m2  'syntax only
'#picaxe 18m2 'ran ok
#no_data
setfreq m16
init:
pause 1000 ; wait for display to initialise
serout 0,n9600_16,(254,1)
pause 2
serout 0,n9600_16,(254,128) ; move to start of  line1
pause 2
serout 0,n9600_16,("1234567890") ; output text
pause 30
serout 0,n9600_16,(254,192) ; move to start of  line2
pause 2
serout 0,n9600_16,("28888888888888888882") ; output text
pause 45
serout 0,n9600_16,(254,148) ; move to start of  line3
pause 2
serout 0,n9600_16,("38888888888888888883") ; output text
pause 45
serout 0,n9600_16,(254,212) ; move to start of  line4
pause 2
serout 0,n9600_16,("48888888888888888884") ; output text
pause 2000
pause 2
pause 2
serout 0,n9600_16,("13333333333333333331") ; output text
pause 45
pause 2
serout 0,n9600_16,("23333333333333333332") ; output text
pause 45
pause 2
serout 0,n9600_16,("30333333333333333303") ; output text
pause 45
pause 2
serout 0,n9600_16,("43333333333333333334") ; output text
      pause 2000
Hi ac21,
Unfortunately I dont have an 08m2 to try.
there can be a slight difference of execution speed using different picaxe chips
I am guessing an 08m2 may be faster?
When having problems always try adjusting pauses between code.
added example to post#38 for you to try hopefully you'll have success...
Back
