I am using a 28x1 to display voltage and current readings on an LCD. I have connected the circuit using the schematic on hippys page
http://www.hippy.freeserve.co.uk/picaxelc.htm#Output_Pin_Definition
I also just cut and pasted his code for the hello world program and got it to work (I had to change 'get' to 'get1' and 'byte' to byte1' as a syntax error kept occuring). So basically I want to display voltage=### and current=### in place of hello and world. I want the real time data to be displayed where ### is to one decimal place (e.g. Voltage = 26.5, Current = 18.3). I am reading the voltage and current on pins 2 and 3 using the readadc10 command. Basically, how do I display on the LCD what the readadc10 command is detecting? It's probably an easy modification to the attached code but I don't know how to do it.
SYMBOL RS = 2 ; 0 = Command 1 = Data
SYMBOL E = 3 ; 0 = Idle 1 = Active
SYMBOL DB4 = 4 ; LCD Data Line 4
SYMBOL DB5 = 5 ; LCD Data Line 5
SYMBOL DB6 = 6 ; LCD Data Line 6
SYMBOL DB7 = 7 ; LCD Data Line 7
SYMBOL RSCMDmask = %00000000 ; Select Command register
SYMBOL RSDATmask = %00000100 ; Select Data register
SYMBOL get1 = b11;
SYMBOL byte1 = b12;
SYMBOL rsbit = b13;
PowerOnReset:
GOSUB InitialiseLcd
DisplayTopLine:
EEPROM 6,("Voltage=")
FOR get1 = 6 TO 13
READ get1,byte1
GOSUB SendDataByte
NEXT
MoveCursorToStartOfSecondLine:
byte1 = $C0
GOSUB SendCmdByte
DisplayBottomLine:
EEPROM 14,("Current=")
FOR get1 = 14 TO 21
READ get1,byte1
GOSUB SendDataByte
NEXT
END
InitialiseLcd:
FOR get1 = 0 TO 5
READ get1,byte1
GOSUB SendInitCmdByte
NEXT
' Nibble commands - To initialise 4-bit mode
EEPROM 0,( $33 ) ; %0011---- %0011---- 8-bit / 8-bit
EEPROM 1,( $32 ) ; %0011---- %0010---- 8-bit / 4-bit
' Byte commands - To configure the LCD
EEPROM 2,( $28 ) ; %00101000 %001LNF00 Display Format
EEPROM 3,( $0C ) ; %00001100 %00001DCB Display On
EEPROM 4,( $06 ) ; %00000110 %000001IS Cursor Move
; L : 0 = 4-bit Mode 1 = 8-bit Mode
; N : 0 = 1 Line 1 = 2 Lines
; F : 0 = 5x7 Pixels 1 = N/A
; D : 0 = Display Off 1 = Display On
; C : 0 = Cursor Off 1 = Cursor On
; B : 0 = Cursor Steady 1 = Cursor Flash
; I : 0 = Dec Cursor 1 = Inc Cursor
; S : 0 = Cursor Move 1 = Display Shift
EEPROM 5,( $01 ) ; Clear Screen
RETURN
SendInitCmdByte:
PAUSE 15 ; Delay 15mS
SendCmdByte:
rsbit = RSCMDmask ; Send to Command register
SendDataByte:
pins = byte1 & %11110000 | rsbit ; Put MSB out first
PULSOUT E,1 ; Give a 10uS pulse on E
pins = byte1 * %00010000 | rsbit ; Put LSB out second
rsbit = RSDATmask ; Send to Data register next
RETURN
