phillavery
Hi
Has any one had any experience with the L6470 Stepper Motor driver which uses an SPI interface (Sparkfun have a breakout board for it)?
I have not used SPI at all, will be a whole new Picaxe adventure, the fact that the driver works autonomously after being told what to do my make up for a lack of speed on the picaxe.
I am particularly interested in the sensorless stall detection feature. This would seem to solve any issues with using a Stepper in an environment where it could be prone to stalling.
Any information/experience would be greatly appreciated
Cheers
Phil
Details:
The L6470 device, realized in analog mixed signal technology, is an advanced fully integrated solution suitable for driving two-phase bipolar stepper motors with microstepping. It integrates a dual low RDS(on)DMOS full bridge with all of the power switches equipped with an accurate on-chip current sensing circuitry suitable for non-dissipative current control and overcurrent protection. Thanks to a unique control system, a true 1/128 steps resolution is achieved. The digital control core can generate user defined motion profiles with acceleration, deceleration, speed or target position, easily programmed through a dedicated registers set. All commands and data registers, including those used to set analogue values (i.e. current control value, current protection trip point, deadtime, PWM frequency, etc.) are sent through a standard 5-Mbit/s SPI. A very rich set of protections (thermal, low bus voltage, overcurrent, motor stall) allows the design of a fully protected application, as required by the most demanding motor control applications.
Key Features
Cheers
Phil
Details:
Key Features
- Operating voltage: 8 - 45 V
- 7.0 A out peak current (3.0 A r.m.s. )
- Low RDS(on) Power MOSFETs
- Programmable speed profile and positioning
- Programmable power MOS slew rate
- Up to 1/128 microstepping
- Sensorless stall detection
- SPI interface
- Low quiescent and standby currents
- Programmable non-dissipative overcurrent protection on high and low-side
- Two-levels of overtemperature protectioI
