RogerTango
Im running a 20X2 at the factory freq, FWICT it is 4mhz. The KBIN is supposed to 'revert' to 4mhz anyway, to read keyboard sigs.
Anyway, I *finally* got some code and wires working together.
The only "problem" (question?) is, it takes about 500 miliseconds from keypress to display on serial terminal window (F8) the result.
Is this typical, for it to take so long??
BTW, I noticed the 3 LEDs on the keyboard will blink once to, I assume, to indicate the keypress was registered and it is ready to accept another keypress. (If you press another key before the blink, it does not register)
Feedback or comments welcome... I had hoped for something a bit more "spiffy"..
Thanks,
Andrew
Thanks,
Andrew
