Goal: To us a simple/cheap joystick to contol forward/reverse of 2 small motors.
Paramaters:
These motors will be used to move a small table (4"x4") on lead screws.
The j/s movement will be porpotional to the movement of the table.
This is NOT a stepper motor application, percision is relative and visual confirmed.
Limit switches will be used to limit the amount of travel in any direction.
The J/S will be tethered to the motors, no wireless requirement here.
The springs on the J/S will be removed so it won't auto center.
The movement of the J/S will change the potentiometers.
The motors will be low speed low voltage, under 5 volts.
A three way switch to toggle UV LEDs, White LEDs and all LEDs off.
Optional:
A single switch to overide the j/s to move the table to center.
Questions:
Which PicAxe is appropriate?
How do I make the j/s movement porpotional?
What have I not thought of?
Mike Duffy
Paramaters:
Optional:
Questions:
Mike Duffy
