interrupt problems picaxe 28x1
sub-bg
we are having problems with our interrupt program for the servos!!
at the moment in doesn't jump straight to the command
it goes through each line of the code and then jumps to a certain condition.
I want to intterupt straight a way.
my code is:
setint %00000001,%00000001
setint %00000010,%00000010
setint %00000100,%00000100
setint %00001000,%00001000
servopos 0,150 ‘ move servo to one end
servopos 1,150 ‘ move servo to one end
pause 2000 ‘ wait 2 seconds
interrupt:
if pin0 = 1 then Fwd
if pin1 = 1 then Rig
if pin2 = 1 then Lef
if pin3 = 1 then Bck
Fwd:
servopos 0,180 ‘ move servo to one end
servopos 1,180 ‘ move servo to one end
'if pin0 = 1 then interrupt
Rig:
servopos 1,120 ‘ move servo to one end
'if pin1 = 1 then interrupt
Lef:
servopos 0,120 ‘ move servo to one end
'if pin2 = 1 then interrupt
Bck:
'if pin3 = 1 then interrupt
does anyone know what we are doing wrong??
Many thanks
You enter the Interrupt: routine but are exiting it with "goto main". It has to be exited with a RETURN, so replace all your 'goto main' with 'return' ( except the first which is part of the main loop ).
Also you have multiple 'SetInt' at the start of the program. Only one SetInt can be active at any one time, the first three will be rendered ineffective by the fourth. You will only get your first interrupt when Input Pin 3 goes high.
Finally, you need to execute a Servo command on each servo pin to start the internal servo handler working. After that you can use ServoPos to set the servo positions without restarting the servo handler.
You will need to diode OR your inputs to one pin so that no matter which input goes high, the interrupt pin will go high. Also connect each input put it's own input pin.
Then, when the interrupt is triggered, check the input pins to see which one caused it.
