This project is a target and display system. The target is a 7x7 grid of phototransistors (PTR's) connected to a PICAXE-40X. Schematics are in the next two posts (limit of two attachments). The display has a 7x7 grid of LED's and an LCD display. I need to be able to have the target always waiting for a serial communication but it also needs to check the PTR's (currently it is only checking 25 of them (5x5 grid for simplicity). Therefore I need to be able to interrupt the targets code and then communicate with it. So, I'm using the setint command. The problem is that the Target only responds some of the time. Is there anywhere in the target's code where it wouldn't respond to and interrupt.
The code for both is attached in this post (one of which being the one that was described as gibberish in another post, now de-gibbered). The schematic will come in the following posts.
