Hi All.
I'm at a bit of a loss, I'm building a Nixie Indoor/outdoor thermometer using a 20M2 and a HV5812. I'm using three of the PWM's to fade the RGB LEDs in and out, and another PWM to run the mosfet for the voltage booster. with all that going on I'm having trouble timing the display to read Indoor temps for ,say, 5 seconds then outdoor temps for 5 seconds. I was hoping to be able to use some sort of internal timer or count clock cycles and trigger an interrupt at the appropriate times. Does anyone know if this is possible?
Thanks in advance
Tony
Thanks in advance
Tony
