Interesting new 433 MHz ASK modules
Goeytex
Honestly, I doubt that a 25mw transmitter is 3000 times more powerful than allowed by the FCC. 25mw at the antenna connection is much different than power levels measured at 3 meters. Are we comparing apples & oranges?
lbenson
As I say, I don't know much about RF, and so am just trying to figure out (i.e., have some knowledgeable person tell me) what the numbers mean with respect to the devices we have available.
Goeytex
Please correct me if I am wrong here ......
The formula came from FCC Web Site. I did the math.
Effective Isotropic Radiated Power
Formula: eirp = pt x gt = (E x d)^2 /30
Definitions:
pt = transmitter output power in watts,
gt = numeric gain of the transmitting antenna
E = electric field strength in V/m,
d = measurement distance in meters (m).
eirp = pt x gt = (E x d)^2 / 30
Given:
E = 5000uv per meter
d = 3 meters
gt = 1 (assuming an antenna gain of 1)
5000uv x 3 = 15000uv = 15mv
15mv ^2 = 225mv = .225v
pt = .225 / 30 = .0075 watts = 7.5mw
7.5mw = 8.75 dBm (Online calculator)
lbenson
Thanks, Goeytex--7.5mW looks like a much more useful number, if correct. Now, how would one attenuate the Dorji module to achieve that power?
Goeytex
At 17dBb these DRA887TX Dorji ASK modules are over the top for legal US limits at 433Mhz. But they could be attenuated by simply operating at less than 5v. Voltage range is 1.5v to 5.5v. The datasheet says output is 10dBm at 3.0v, which if you consider normal losses will likely get you to close to US legal limits and somewhere in the 100 meter range or better.
The Dorji GFSK Modules are software configurable from 0 dBm to max in either 7 or 10 steps. Configure with a software utility or by Picaxe serout. These are really nice modules with 5 times the range of ASK given the same power levels.
manuka
Goeytex: My quick testing shows those ASK TX power outputs indeed relate nicely to supply voltage. I also fully agree that Dorji's GFSK offerings are streets ahead in bang for buck performance. For the record however-are you effectively saying 10dBm is FCC acceptable in the US on 433MHz ? See my direct email to you re both this & figures in post #43 above. Stan.
Goeytex
Stan: Don't put me on the record yet. But it all boils down to field strength at 3 meters regardless of manufacturer dBa specifications.
For home built devices the FCC requires that you make a reasonable effort to be in compliance and not knowingly or intentionally operate your device above legal RF limits. The FCC also realizes that the home builder cannot measure field strength and therefore does not require licensing or certification for up to 5 devices.
manuka
Update: Further testing (& tone sending "persuasion") of these cheap DORJI modules has been most satisfactory, with LOS tone reception ranges to ~5km. These findings (+ tweaks & updates) are included in a now 7 page "heads up" .pdf -sample screen grab below. Copyleft- but credit appreciated. Stan.
srnet
Indeed.
I have had reliable machine decoded (laptop or my portable magic morse decoder) at 25mW, 433Mhz and 60WPM Morse at 4.8kM ........
That was with the RFM42 transmitter, but the receiver setup was the same.
