I don't have access to a Picaxe the next few days (4th of July weekend...) to try it out myself, so I hope somebody else can answer this:
What is the idle state of the serial out pin (the one that gets driven by sertxd)? I assume it's low, correct?
The reason I am asking, I have a project where I am running short by just one output pin, so I thought I could (ab-)use the serial out pin. It would go to a counter reset, so I could do the reset by sending an arbitrary byte through sertxd (I don't care if this makes the output toggles a few times, as long as i toggles at least once from low to high and then back to low, and then stays there). At the moment that's on a 40X1, but later I'll use a 40X2 (when available).
I remember the there was a way on some Picaxe (the 18X?) to use the serial out pin as a regular output by using poke commands, but can't find that anywhere. Can somebody point me to the respective information? (Hippy?)
Thanks in advance,
Wolfgang
Thanks in advance,
Wolfgang
