AlastairD(Aus)
I have need to share data between 2 picaxe modules, one a data logger measuring the cell voltages and temps of a bank of LiFePO4 batteries in the off road motorhome I am building on a Isuzu 4wd truck. This module using a 28X2 will be in a not so accessible spot running all the time. I will also have another unit (using either a 28X2 or more likely an 18M2+) with a display monitoring other temps and things. I want to be able to upload data on command and am happy about how to do it but would appreciate advice from the forum re the mode. I am already using i2C for communication b/n display, RTC, temp sensor etc but this is only relatively short distance.
Which form of communication has better noise immunity and likely to be less problematic, I2C or serial? I will use shielded twisted pair wire in either case for the 4 metre long run. Having great fun building bits using Picaxe, probably not necessary but fun to do and I always like knowing what is going on with things.
cheers
cheers
