2C driver using bit bang. This can be used with any microcontroller which has 2 GPIO lines which can be configured as input/output
typedef struct
unsigned int PIN0:1;
unsigned int PIN1:1;
unsigned int PIN2:1;
unsigned int PIN3:1;
unsigned int PIN4:1;
unsigned int PIN5:1;
unsigned int PIN6:1;
unsigned int PIN7:1;
} PORT;
/* TODO: Example address shown, but the proper address */
#define PORT0 *(volatile PORT *)0x1234
/* Define the port used for I2C data and clk as shown above to access them pin wise */
#define I2C_DATA PORT0.PIN0
#define I2C_CLK PORT0.PIN1
#define HIGH 1
#define LOW 0
/* I2C Start - bit bang */
void I2C_START(void)
/* I2C Start condition, data line goes low when clock is high */
I2C_DATA = HIGH;
I2C_CLK = HIGH;
I2C_DATA = LOW;
I2C_CLK = LOW;
/* I2C Stop - bit bang */
void I2C_STOP (void)
/* I2C Stop condition, clock goes high when data is low */
I2C_CLK = LOW;
I2C_DATA = LOW;
I2C_CLK = HIGH;
I2C_DATA = HIGH;
/* I2C Write - bit bang */
void I2C_WRITE(unsigned char data)
unsigned char outBits;
unsigned char inBit;
/* 8 bits */
for(outBits = 0; outBits < 8; outBits++)
if(data & 0x80)
I2C_DATA = 1;
I2C_DATA = 0;
data <<= 1;
/* Generate clock for 8 data bits */
SCLK = HIGH;
SCLK = LOW;
/* Generate clock for ACK */
I2C_CLK = HIGH;
/* Wait for clock to go high, clock stretching */
while(I2C_CLK);
/* Clock high, valid ACK */
inBit = I2C_DATA;
I2C_CLK = LOW;
unsigned char I2C_READ (void)
unsigned char inData, inBits;
inData = 0x00;
/* 8 bits */
for(inBits = 0; inBits < 8; inBits++)
inData <<= 1;
I2C_CLK = HIGH;
inData |= I2C_DATA;
I2C_CLK = LOW;
return inData;
/* Examble for writing to I2C Slave */
void writeI2CSlave (unsigned char data)
/* Start */
I2C_START();
/* Slave address */
I2C_WRITE(0xAA)
/* Slave control byte */
I2C_WRITE(0xBB);
/* Slave data */
I2C_WRITE(data);
/* Stop */
I2C_STOP();
/* Examble for reading from I2C Slave */
unsigned char readI2CSlave(unsigned char data)
unsigned char inData;
/* Start */
I2C_START();
/* Slave address */
I2C_WRITE(0xAA);
I2C_WRITE(data);
/* Stop */
I2C_STOP();
/* Start */
I2C_START();
/* Slave address + read */
I2C_WRITE(0xAA | 1);
/* Read */
inData = I2C_READ();
return inData;
Please could you help me translate this code to Picaxe .And tell me have a software ( Sale or free and easy to use for newbie as me ) for converter to picaxe code. Many thank you in advance.
lamxe
