beaniecrocker
Can anyone tell me first off if when I hook a tact switch up to an input does the other end just hook to a ground or does it need to connect to a power source.... The other is a programming issue I just taught myself how to program by reading the manuals in the programming editor for 6 hours between reading and programming at the same time and I was wondering why only 1 output is working on my breadboard and the program is not running off of my switch pin3...here is my prog.
symbol rfbutton = pin3
pause 150
if rfbutton = 0 then rf1
rf1:
high 1
high 0
pause 22
low 1
low 0
pause 18
high 1
high 0
pause 22
low 1
low 0
pause 18
high 1
high 0
pause 22
low 1
low 0
pause 18
high 1
high 0
pause 22
low 1
low 0
pause 18
if rfbutton = 1 then goto rf2
goto rf1
rf2:
high 1
high 0
pause 100
low 1
low 0
pause 100
if rfbutton = 1 then goto rf3
goto rf2
rf3:
for b0 = 1 to 3
high 1
high 0
pause 50
low 1
pause 50
if rfbutton = 1 then goto main
next b0
goto rf3
end
It works in simulation but when I put it to the breadboard or in use It just doesn't work right
pause 150
rf1:
high 1
high 0
pause 22
low 1
low 0
pause 18
high 1
high 0
pause 22
low 1
low 0
pause 18
high 1
high 0
pause 22
low 1
low 0
pause 18
high 1
high 0
pause 22
low 1
low 0
pause 18
goto rf1
rf2:
high 1
high 0
pause 100
low 1
low 0
pause 100
goto rf2
rf3:
for b0 = 1 to 3
high 1
high 0
pause 50
low 1
pause 50
next b0
goto rf3
end
