readadc 1,b1 ‘ read humidity value
let b1 = b1 - 41 * 100 / 157 ‘ change to %RH
debug b1 ‘ display on computer screen
pause 500 ‘ wait 0.5 second
goto main ‘ loop
now . . . . can you help me figure out now to measure barometric pressure with a PICAXE.
For the HP03 sereis of barometric Pressure sensors, the datasheet gives the formula requred. About 7 in total to complete the calculationWell, I suppose that would not be a problem if you put it like that, however is the HP03 easy to use? Like the humidity sensor?
Hi All, I have checked out this sensor on MUTR, cheap ($0.75NZ ea), looks simple to use, resistance easily read by picaxe ADC. Only problem, MUTR quote incredible price to ship to New Zealand, like 30 pounds mininum.Have you seen this ?
http://www.mutr.co.uk/product_info.php?products_id=267
I've used MUTR in the past and found them very helpfull.
Cannot help with you specific query.Hi All, I have checked out this sensor on MUTR, cheap ($0.75NZ ea), looks simple to use, resistance easily read by picaxe ADC. Only problem, MUTR quote incredible price to ship to New Zealand, like 30 pounds mininum.
Does anyone know where this can be purchased locally or even what make/model it is?
Regards, Kevin T
Cannot help with you specific queri.
It is great to find such cheap items but freight can often be exceedingly high. I have found this applies for purchasing items out of the US for example. -END QUOTE]
Thanks for the quick reply, and the links.
I have searched, but never seen anything as cheap as the ones at MUTR, nor as easily interfaced. I will keep looking.
May I take this oportunity to say I have never seen a forum as well run as this, nor one so well used. The quality of members and postings is a credit to you all.
Thank you,
tommo
Regarding this part, does anyone have a manufacturer and part number? I didn't see any documentation referenced on the MUTR site.Have you seen this ?
