So I have just started to play with a new 20m2 chip that I am using for a project and just spent the last 2 hours trying to get my AXE133 serial lcd to work. I finally busted out the scope and could clearly see there was a problem with the output on signal. For some reason the square waves are jittering really bad. If I switch back to software serial then steady as can be and works. Back to hardware no go. So what is happening?! The hardware setup is barebones, 10k and a 22k resistor and 5v regulator with a couple filtering caps. Any ideas? I am just trying to write hello:
int:
setfreq m4
hsersetup b2400_4, %10
hserout 0,(254,1)
Pause 2000
Main:
hserout 0,("hello")
pause 50
