PS please use the word PICAXE not 'Pickaxe'. It is written several times on the forum so it is difficult to understand your reason for spelling it as such.
I cnduo't bvleiee taht I culod aulaclty uesdtannrd waht I was rdnaieg. Unisg the icndeblire pweor of the hmuan mnid, aocdcrnig to rseecrah at Cmabrigde Uinervtisy, it dseno't mttaer in waht oderr the lterets in a wrod are, the olny irpoamtnt tihng is taht the frsit and lsat ltteer be in the rhgit pclae. The rset can be a taotl mses and you can sitll raed it whoutit a pboerlm. Tihs is bucseae the huamn mnid deos not raed ervey ltteer by istlef, but the wrod as a wlohe. Aaznmig, huh? Yaeh and I awlyas tghhuot slelinpg was ipmorantt! See if yuor fdreins can raed tihs too.
Not fair John! Being dyslexic and not familiar with the word I spent some time finding that 'sektion' is a German word.I want in on the speling sektion!
Not sure how any of this is helping Tyler choose a transistor?What do the PIC and PICAXE abbreviations stand for?
PIC and PICAXE are registered trademarks, they are not abbreviations for any words. The official answer from Microchip's legal department is: "Trademarks are used to identify the source or origin of a product. As such, they are a branding tool.
Said another way, if you are driving a 1 Amp load via a 100 Hfe transistor, your base current is 1A / 100 = 10mAYes it is possible to still choose a transistor with the wrong ratings. What you need is one with a high Hfe (gain)figure. This effectively means that less Base current is required for the same Collector current.
Hope that makes sense to you.
please go back and read the steps in post 3.so if i just pick one that is higher rated then i need then it will just give the voltage into the colector?
what about the base tho will any transistors take to much current from the base and wreck the PICAXE? or is the PICAXE protected from this? thanks
Tyler
As mentioned in post 3 working with the transistor in the saturated mode will reduce Vce (and heat dissipation) but the gain Hfe(sat) is typically about a tenth of the Hfe in the linear region so need to check the datasheet for the intended transistor.Said another way, if you are driving a 1 Amp load via a 100 Hfe transistor, your base current is 1A / 100 = 10mA
The total transistor current is 1000mA + 10mA = 1.01A
Yes, caveats exist and abound with every aspect of electronics and Post #3 is very well written for selection. I did a poor job on my late night write-up meant to impart a rule-of-thumb; it should have been prefaced with something such as, "For 3-terminal transistors, the sum of the the Collector current, Ic, and the Base current, Ib, represents the total current handled by the device, in D.C. mode. Operating Hfe (as opposed to published Hfe) is the ratio of Ic / Ib." Even this is not entirely precise, but should be adequate for the purpose at-hand.<...>
