retepsnikrep
I just built a fairly complicated circuit using a 28X1 and it won't accept the program download. I have tied all the floating inputs to ground via resistors.
I have tried without a resonator and with an 8mhz res fitted. The same board also contains an 08M which is working and downloads fine via the serial cable. I'm using the latest editor. The download just times out with the standard "it's not connected or powered message". The chip has the correct voltages on the power pins. The SV2000 is working and outputs it's welcome screen before then starting to print garbage which is related to it's floating input and noise on pin 3 and the fact trhe 28X1 is not working. (I'll add a pull down resistor for this in the next version)
Have I been unlucky and got a duff one? Anything glaringly obvious on the Schematic?
The schematic is here
www.solarvan.co.uk/bms/Master120808.jpg
A picture of the board is here
www.solarvan.co.uk/bms/MasterPcbPop.jpg
Jumpers JP1- JP3 are closed to pull down the unused ADC Inputs.
Jumper JP4 is open during this testing phase, so the Watchdog 08M U7 has no effect on the 28X1
I wish I had used an IC socket now!!
How best to unsolder a 28 pin IC from the board?
How critical are the decoupling capacitors? I used 100n poly is that a big mistake? I can soon solder some ceramic ones onto the board, suggestions?
The SV2000 chip works at 20mhz producing an RCA Video signal output so It could be generating some noise.
This is not a commercial project, it's my battery management system, for which the schematics and source are freely available.
