I salvaged some motors from a printer and they don't run very fast off a 5 volt battery.... so I thought hey maybe I should connect them up using the mains adapter which came with the printer - which is marked as 32V outputting 1300mA
Well, anything above a 9V battery makes me think I will probably electrocute myself, so I stick to AA's mostly. But then I thought maybe I should actually try to learn enough to know what is dangerous and why.
So I found some sites explaining about the conductivity of human skin, and the thresholds in terms of current that will cause death. For example
http://electronics.stackexchange.com/questions/19103/how-much-voltage-is-dangerous
Also I understand that if the current passes through your heart then it is more dangerous, whereas if it enters and exits your finger, then it is less so. But still it doesn't quite make sense for me...
There is no obvious census on this - some sites say 10mA through the heart would be fatal and some say 500mA without mentioning the path. Big difference. But some of the resistance values given are quite large - even wet skin has a resistance of 1kohm according to a few sites I have seen. Well, 240/1000 = 0.24? - which is nowhere near the 500mA quotes on the site I linked to.
I don't plan to start grabbing hold of live 240v wires - I know empirically that this is a B.A.D.I.D.E.A. But I am just interested to know how you actually prove theoretically the maths on whether something will harm you, which would make me feel more confident about knowing what is what.
For example, I guess if I grab a single live 240V wire, with skin resistance of 1k - then this will allow 240mA to pass through my body to ground through my feet, and if it decides to travel the scenic route, no wonder it would be curtains for me. But if I grab the earth wire first, and then touch the live wire to the same hand....would this theoretically mean only a portion of my hand is conducting, and I would just get a burn rather than a heart seizure?
But then again, according to that link, dry skin has a much much higher resistance of around 1M. But if I were to allow someone to touch a live 240V wire to the back of my dry hand, this theoretically means the current the skin would allow would be less than a milliamp - 240/1000000 = 0.00024? But that implies I would be getting current which is theoretically less than the perceptible amount?! I must be calculating this wrong surely, because somehow I doubt I would be chatting about the weather while they did that.
And then 32V. So if I grab a live 32V wire, and ground it via my body - if my skin resistance when wet is really 1k, then this gives a current of 32/1000 = 0.32 If that goes via my heart it could kill me, right? But what would make it go via my heart - because according to that link, if it DOESN'T, then I would just get some controllable muscle cramps. Does that mean working with 32V off the mains is essentially just as dangerous as working with a 240V wire, or only likely to cause real danger if you are unlucky?
I don't fancy connecting myself up to the mains and trying to write notes and observations at the same time to work this out...so could anyone enlighten me about how you would go about calculating the results of touching different wires, in different ways? It might make me feel a bit more confident about doing things with relays or wall plugs when I need to.
Thanks
Thanks
