Hello,
While working with my latest project, i noticed that the command HIGH BIT0 doesn't work. The program works, if i replace the statement by let bit0 = 1.
However, i remember using the high bit0 command on an earlier project with picaxe 20M.. Though i'm not sure if it worked, because i didn't finish it =).. The reason why high / low bitx might be useful, is that it seems to use less program space that way.
So, does that command even work, or does the PE accept the command by mistake?
edit. I'm using PE 5.2.6
