Hi there,
I am testing a tmp 36. The middle pin of the sensor is connected to the adc pin of an 08m2 and I am writing the value to b0. I'm reading the b0 value in the terminal via the axe027 (thanks forum members for the advice there). What value am I seeing in the terminal? For instance I get a value of 56 or 39 this morning when it was colder...is that the value in milivolts? Of so, do I then do a conversion using the ratio 75 mv = 25 deg c so 56 is 18 deg c or thereabouts? Does it matter what my input voltage is? The data sheet says it can run from2.7 v to 5.5v and I'm running off a 3 aa battery pack. Any advice gratefully received!
Thanks
Rob
Thanks
Rob
