Once again thank you for your Time.
Specially the guidance you can Provide me with.
I'm not even sure if it can be done.
I was reading other post close related to my Project but they differ, most only want some string of data or commands to run Relays.
My project consist on a digital panel with USB connection for communication.
With a Portable PC I can connect locally via usb and through the panel software I can make changes or monitor the panel.
I will like to connect to the panel from a remote location.
GSM came to my mind since there is no Land line available.
If I Use a gsm modem to call the panel (connect) from my pc and another GSM modem to answer on the panel side?
Keeping in mind that the panel connection port is USB.
If so can I use a 28X1 picaxe chip to answer the call to make the connection?
Or is there something else that could work better.
Any Ideas and comments are more then Welcome and greatly appreciated.
