Hey,
my plan is building a LED display thermometer.
i will have a DS18B20 connected to a PICAXE 40X2.
the 40X2 will have let's say 20 LEDs connected to it - each led on another output.
making a bargraph using these 20 leds, it will make a thermometer starting with the 1st LED showing 10*C, 2nd led indicating 11*C... until led 20 which will indicate 30*C.
each led that lights up will symolize 1*C increament.
well i think you've got it.
MY QUESTIONS are:
i want to keep it simple, thus i want the PICAXE output to directly drive LEDs. not supporting logic\serial decoders and stuff.
how many LEDs could i connect to a 40X2 ? (considering i need 1 input to be used by the DS18b20)
do i have to buy an external 4Mhz resonator for the 40X2 on this project ? or it has an internal one ?
*** if i'm short on outputs - I dont mind using each led increament as 2*C step to have a wider temperature scale.
i plan it to be more a visual effect than a precision device (though i still want to be able to read the temp at +\- 1*C)
any further thoughts ?
thanks!
MY QUESTIONS are:
thanks!
