Help please
HAZELEB
Hi, I have an 18x connected to the LCD using the Serial LCD firmware and 24lC16B EEPROM
I am trying to write the letters A-Z and 0-9 to the EEPROM and then read then back alphabetically
To spell out a name on the LCD, I want to use a push switch to move through the alphabet until
I find the letter then advance the cursor for the next one until I have spelt the name and then save back into another block of the EEPROM to recall at a latter date, I am not sure if this is the best way to do this or if it can be done, I am not looking for someone to right a program for me just a bit of help please Thanks.
ylp88
I did something similar a LONG time ago with a 28X. It split the EEPROM into its 8 separate locations for 8 different messages. The register was selectable at runtime and the program would prompt the user to select which register to use, then after selection of the register, whether they wanted to read the register, or write to it. Long messages would automatically scroll. The LCD was not serially interfaced - direct parallel connection.
A start-up routine consisted of the firmware version and a welcome message. After a period of time, it would prompt the user to press the "Start" button until which time it would display the temperature from a digital temperature sensor.
I usually don't do this but I'll post the code in full because you probably can't use it without quite a lot of modification and even still, it is not exactly what you want. Perhaps it can be of some "inspiration"...
Hopefully the comments will help you follow my mediocre programming. The code can easily be optimised but works fine as it is. It was built into a working circuit (from breadboard to PCB) so all should be good...
<code><pre><font size=2 face='Courier'>' DECLARE PINOUTS
' Analog 0 - Light Level Sensor
' 1 - Not Used
' 2 - Not Used
' 3 - Not Used
' Input 0 - Button: Select
' 1 - Button: Right
' 2 - Button: Left
' 3 - i2c Clock
' 4 - i2c Data
' 5 - Dallas One-Wire Temperature Sensor
' 6 - Not Used
' 7 - Not Used
' Output 0 - LCD Backlight
' 1 - Busy LED Indicator
' 2 - LCD: Register Select (RS)
' 3 - LCD: Enable (E)
' 4 - LCD: Par. Data 4 (DB4)
' 5 - LCD: Par. Data 5 (DB5)
' 6 - LCD: Par. Data 6 (DB6)
' 7 - LCD: Par. Data 7 (DB7)
' DECLARE SYMBOLS
symbol btnSel = pin0
symbol btnRight = pin1
symbol btnLeft = pin2
symbol ledBusy = 1
' DECLARE INTERNAL EEPROM
eeprom 0, (&quot;Welcome Yang-Lit&quot;)
eeprom 16,(&quot;F/W Version 5.0a&quot;)
eeprom 32,(&quot;Select register:&quot;)
eeprom 48,(&quot;&lt;-Read | Write-&gt;&quot;)
eeprom 64,(&quot;Please wait... &quot;)
eeprom 80,(&quot;Temperature: &quot;)
eeprom 96,(&quot;File Saved! &quot;)
eeprom 112,(&quot;Press to Start &quot;)
' VARIABLE DECLARATION
' b0 = Temporary Temperature reading
' b1 = LCD Reserved (wrchr/wrins)
' b2 =
' b3 = For/Next loop
' b4 = Lookup position
' b5 =
' b6 =
' b7 =
' b8 =
' b9 =
' b10 =
' b11 =
' b12 =
' b13 =
' MAIN ROUTINE START
init: ' Initialize LCD in 4-bit mode
let pins = 0
let b4 = 0
pause 200
let pins = 48
pulsout 3,1
pause 10
pulsout 3,1
pulsout 3,1
let pins = 32
pulsout 3,1
pulsout 3,1
let pins = 128
pulsout 3,1
let b1 = 14
let pins = b1 &amp; 240 ' WRINS
pulsout 3,1
let b2 = b1 * 16
let pins = b2 &amp; 240
pulsout 3,1
high 2
reset:
b1 = 0
b2 = 0
b3 = 0
b4 = 0
b5 = 0
b6 = 0
b7 = 0
b8 = 0
b9 = 0
b10 = 0
b11 = 0
b12 = 0
b1 = 1 ' Clear screen
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
For b3 = 0 to 15 ' Introductory messages
read b3, b1 ' * &quot;Welcome Yang-Lit&quot; *
let pins = b1 &amp; 240 ' WRCHR
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
Next b3
b1 = 192
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
For b3 = 16 to 31
read b3,b1 ' * &quot;F/W Version 5.0a&quot; *
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
Next b3
pause 1500
login:
b1 = b1 + 1
If b1 = 255 Then dispTemp
If btnLeft = 0 And btnRight = 0 And btnSel = 0 Then Login
b10 = 0
pause 250
b1 = 1 ' User select external EEPROM register
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
for b3 = 32 to 47
read b3,b1 ' * &quot;Select register:&quot; *
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
pause 5
next b3
b1 = 192
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
b3 = 1
SelReg:
b1 = 192
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
b1 = b3 + 48
sertxd (b3)
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
waitselreg:
if btnRight = 1 And b3 = 7 Then regMax
if btnRight = 1 And b3 &lt; 7 Then regUp
if btnLeft = 1 And b3 = 0 Then regMin
if btnLeft = 1 And b3 &gt; 0 Then regDown
if btnSel = 1 Then initReg
goto waitselreg
initreg:
pause 250
b3 = %10100000 + b3
i2cslave b3, i2cfast, i2cbyte ' Set block in EEPROM to use
b10 = b3
ReadorWrite: ' Ask user: &quot;Read or Write?&quot;
b1 = 1
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
for b3 = 48 to 64
read b3,b1
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
pause 5
next b3
waitRW:
If btnLeft = 1 Then eeRead
If btnRight = 1 Then eeWrite
goto waitRW
eeRead:
sertxd (&quot;Read process started&quot;,13)
b1 = 1
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
For b3 = 0 To 255 ' Read the whole message from external EEPROM
readi2c b3,(b1)
sertxd (b1)
If b1 = $FF Then MsgEnd
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
pause 5
Next b3
MsgEnd: ' End of the message found
If b3 &lt; 15 Then Goto waitRST
b1 = 24
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
pause 200
If btnSel = 1 Then reset
goto MsgEnd
eeWrite:
b1 = 1
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
for b3 = 64 to 79 ' &quot;Please wait&quot; message as deleting takes time
read b3, b1
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
pause 5
next b3
b1 = 192
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
for b3 = 0 To 255 ' Delete EEPROM data with $FF (255 or %11111111)
writei2c b3, ($FF)
pause 10
If b3 = 16 Or b3 = 32 Or b3 = 48 Or b3 = 64 Or b3 = 80 Or b3 = 96 Or b3 = 112 Or b3 = 128 Or b3 = 144 Or b3 = 160 Or b3 = 176 Or b3 = 192 Or b3 = 208 Or b3 = 224 Or b3 = 240 Or b3 = 256 Then pgbAdd
pgbAdded:
next b3
sertxd (&quot;Write process started&quot;,13)
b1 = 1
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
rstLU:
b4 = 0 ' Reset lookup position
For b3 = 0 to 255
lookup b4,(&quot;ABCDEFGHIJKLMNOPQRSTUVWXYZ &quot;,$ff,&quot;abcdefghijklmnopqrstuvwxyz &quot;,$ff,&quot;1234567890!@#$%^&amp;*()-+=:.?,&quot;,$FF),b1
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
pause 5
pause 125 ' Debounce and switch delay
waitChrSel:
If btnLeft = 1 Then prevChr
If btnRight = 1 Then nextChr
If btnSel = 1 Then selChr
goto waitChrSel
nextChr:
If b4 &lt;&gt; 83 Then nextC
b4 = 255
nextC:
b4 = b4 + 1
goto ChrInc
prevChr:
If b4 &lt;&gt; 0 Then prevC
b4 = 84
prevC:
b4 = b4 - 1
goto ChrInc
chrInc:
b1 = 16
pulsout 3,1
let b2 = b1 * 16
pulsout 3,1
high 2
Next b3
goto rstLU
selChr:
b6 = b1
writei2c b5,(b1)
b5 = b5 + 1
If b1 = $FF Then wrEnd
'b1 = 192
'let pins = b1 &amp; 240 ' WRINS
'pulsout 3,1
'let b2 = b1 * 16
'let pins = b2 &amp; 240
'pulsout 3,1
'high 2
b1 = b6
high 2
pulsout 3,1
let b2 = b1 * 16
high 2
pulsout 3,1
If b5 &gt; 15 Then LCDscroll
goto chrInc
END ' ~ ~ ~ The End ~ ~ ~
' SUPPLEMENTARY ROUTINES HERE '
dispTemp: ' DISPLAY TEMPERATURE ON LCD '*
If b10 &lt;&gt; 0 Then wrTemp '*
b1 = 1 ' Clear screen '*
let pins = b1 &amp; 240 ' WRINS '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
let pins = b2 &amp; 240 '*
pulsout 3,1 '*
high 2 '*
For b3 = 112 to 127 '*
read b3, b1 ' * &quot;Press to Start&quot; * '*
let pins = b1 &amp; 240 ' WRCHR '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
Next b3 '*
b1 = 192 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
pulsout 3,1 '*
high 2 '*
For b3 = 80 To 95 ' * &quot;Temperature: &quot; '*
read b3,b1 '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
Next b3 '* '*
wrTemp: '*
For b3 = 1 To 3 '*
b1 = 16 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
pulsout 3,1 '*
high 2 '*
Next b3 '*
readtemp 5,b0 ' Read the temperature '*
b10 = b0 // 10 ' Split number into two digits '*
b0 = b0 / 10 '*
b1 = b0 // 10 '*
b1 = b1 + 48 '*
let pins = b1 &amp; 240 ' Send first digit '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
b10 = b10 + 48 '*
b1 = b10 '*
let pins = b1 &amp; 240 ' Send second digit '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
b1 = &quot;C&quot; ' &quot;C&quot; for Celcius '*
let pins = b1 &amp; 240 '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
b1 = 0 '*
goto login '*
regMax: ' REGSEL BUFFER AT MAX. '*
b3 = 0 '*
pause 250 '*
goto SelReg '*
regUp: ' REGSEL BUFFER SET UP '*
b3 = b3 + 1 '*
pause 250 '*
goto SelReg '*
regMin: ' REGSEL BUFFER AT MIN. '*
b3 = 7 '*
pause 250 '*
goto SelReg '*
regDown: ' REGSEL BUFFER SET DOWN '*
b3 = b3 - 1 '*
pause 250 '*
goto SelReg '*
waitRST: '*
If btnSel = 1 Then reset '*
goto waitRST '*
LCDscroll: '*
b1 = 24 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
pulsout 3,1 '*
high 2 '*
goto chrInc '*
wrEnd: '*
For b3 = 96 To 111 ' * &quot;File Saved! &quot; '*
read b3,b1 '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
Next b3 '*
wreset: '*
If btnLeft = 1 Or btnRight = 1 Or btnSel = 1 Then reset '*
goto wreset '*
pgbAdd: '*
b1 = $FF '*
high 2 '*
pulsout 3,1 '*
let b2 = b1 * 16 '*
high 2 '*
pulsout 3,1 '*
pause 5 '*
goto pgbAdded '*
' SUBROUTINES ROUTINES HERE '
</font></pre></code>
There... unedited, as is, as it was some two years ago...
<b><i>ylp88 </b> </i>
ylp88
Just realised how long it is... sorry. The main code is at the top while the sub-routines are at the bottom and are pretty standard. Most of the &quot;ideas&quot; will probably come from the top section.
<b>It might end up confusing you more than it help - post if you need clarification and I'll try and get back to you ASAP... Apologies in advance. </b>
And don't ask - I have no idea what all those &quot;*&quot; down the right-hand-side of the end of the program were for...
Edited by - ylp88 on 26/03/2006 17:21:25
HAZELEB
Hi. ylp88
Thanks for your fast response and the code I am sure all I need will be in there
It will take me some time to get my head around it but will let you now how I get
on many thanks again.
Regards,
Hazeleb.
