Hi
Please can someone help with this. I have a 14m2, I was using this chip with an LCD screen called texstar. I have been using this combination for a couple of years without problems, However the texstar LCD from coolcomponents is no longer available. I need a similar low porfile LCD for our product. (I couldnt get the screen from PICAXE to fit in our box, otherwise I would have used that). I have sourced a screen from Sparkbright sold by proto-pic that has a low profile (SERIAL ENABLED 16X2 LCD - WHITE ON BLACK 5V)
Unfortunaly the info and help files associated with it are limited and I am uable to change the baud rate of this lcd. I can send and display data at 9600baud which is the default but I need to display info at 2400baud to suit my application. Can someone please explain how I change the baud rate using my PICAXE serial port as the helpfiles associated with this product talk in "Arduino" and talk about things like "send a special character" followed by control K..??? (I am not familar with arduino!!)
please see paragraph 3.4 on this PDF
Any help appreciated.
Thanks
JPU
Thanks
JPU
