Hello all, great to have found you all, as did electronics back in the 80's as also basic programming. Granted a bit rusty but it is slowly coming back to me.
Bought the developers kit and been playing, so far so good, got a chase circuit worked out and flashing leds etc, now transferring to a strip board as the first project.
Using 10mm led's which have the same values at 3 and 5mm ones, which for the red ones I have is, 20ma 1.75-2.2V and white ones with 20ma 3.2-3.4V .
Reading the data for the chips, and testing on the board one led per chip pin is fine, but have confused my self with the resistor needed per led.
In the manual it says 330 ohm is normal for led's, but using a resistor calculator for 4.5v - 5v power supply and the 20ma and average V of 2v for red and 3.3v for white I get red at 150 ohm and white at 91 ohm..... Am I missing something?
Any advice would be great.......
PS Nice to be here......
