A servo has an internal pot which turns as the motor turn and senses the motors position. The mechanical stop protects the pot from being turned beyond it's limits.
Has anyone removed the mechanical stops and the pot. Then wire the pot back into the servo with extended wires?
Seems to me that if you then send the servo a servo command of say 150 the motor would turn until you physically turn the pot to it's middle (150) position. You can make the motor turn in either direction, for as many turns as you want, by simply turning the pot in either directions from middle. The motor would stop where ever you want it to. All with a single command from the picaxe.
